Author Topic: smoke screw  (Read 2588 times)
August 27, 2010, 04:20:38 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
smoke screw
« on: August 27, 2010, 04:20:38 pm »
hey so i think i have an idea as to why my car smokes like a semi, im pretty sure the smoke screw has been dicked with over the years because the lock nut has been loosened. does anyone know off the top of their heads how many turns (while bottomed) out it is? or how to set it to where its supposed to be, thanks.
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #1August 27, 2010, 04:51:47 pm
  • 3255
    • My collection of HOWTOs
Re: smoke screw
« Reply #1 on: August 27, 2010, 04:51:47 pm »
It's gonna be different from pump to pump to pump... try backing it out 1/2 a turn at a time and see what happens.  You may have to adjust your idle as you do so.
Reply #2August 27, 2010, 05:37:24 pm
Re: smoke screw
« Reply #2 on: August 27, 2010, 05:37:24 pm »
as the smoke disappears, so will the power...
Reply #3August 27, 2010, 10:25:18 pm
Thezorn
  • 381
Re: smoke screw
« Reply #3 on: August 27, 2010, 10:25:18 pm »
True, but only at a certain point. If you have the "max fuel screw" in to much truning it out can maybe give you a bit more power, since it was being flooded with to much diesel before.
The best way to adjust the pump is to play with your max fuel screw and your idle as it is running. It is very easy to here when you have it in the right range and the idle sounds nice.
« Last Edit: August 27, 2010, 10:32:51 pm by Thezorn »
Compounded 93 AAZ
Reply #4August 29, 2010, 09:43:33 am
jettabrendan
  • 198
Re: smoke screw
« Reply #4 on: August 29, 2010, 09:43:33 am »
oh im talking about the scerw on top of the lda, when i got the car the jam nut was loose and thats a indication of it being messed with.
Reply #5August 30, 2010, 11:04:41 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
Re: smoke screw
« Reply #5 on: August 30, 2010, 11:04:41 am »
just undo it until it's where you want it to be. turn it out until it doesn't effect the idle at all.
It should only add fuel on boost. if it was pushed down to the point where it smokes like crazy just undo it like Vince Waldon suggested. take all of ... 20 minutes and a few laps around the block to get it right probably.
Ed
