Author Topic: Tuning N/A 1.6D  (Read 6222 times)
August 27, 2010, 08:35:11 am
Mrphish89
  • 9
Tuning N/A 1.6D
« on: August 27, 2010, 08:35:11 am »
Hello! I'm new to this forum, but I've been having a read and I like what I see! :) Basically I have a 1989 1.6d caddy, the engine is completely standard and I love how economical it is (usually about 600 miles a tank) but hate how slow it is! What can I do to make it a bit quicker? I've been reading about gov mod pump, what difference will this make performance wise? Is there much else I can do to get much more power out of it without spending a fortune on balancing, porting and balancing or fitting a turbo etc..... Thanks a million in advance! :)
Reply #1August 27, 2010, 09:05:40 am
honda_is_the_best
  • 104
Re: Tuning N/A 1.6D
« Reply #1 on: August 27, 2010, 09:05:40 am »
VW it aint just a car, its a way of life..... Boost, Soot, Repeat
Reply #2August 27, 2010, 09:21:30 am
Mrphish89
  • 9
Re: Tuning N/A 1.6D
« Reply #2 on: August 27, 2010, 09:21:30 am »
Thanks!!!!!
Reply #3August 28, 2010, 05:47:29 am
Vanagoner
  • 219
Re: Tuning N/A 1.6D
« Reply #3 on: August 28, 2010, 05:47:29 am »
One of these and an appropriate dual downpipe will make a huge difference-  it has for me.
1989-ish supercharged Corrado 8V dual exhaust manifold.  It bolts right up.
Sage
'82  Vanagon Westy, the mighty N/A
Reply #4August 28, 2010, 06:08:54 am
Mrphish89
  • 9
Re: Tuning N/A 1.6D
« Reply #4 on: August 28, 2010, 06:08:54 am »
Ahhh brilliant thanks! What setup and engine are you running? I don't really want to turbo my 1.6d because eventually I'm going to do a aaz conversion. How much power can you get out of the 1.6d without killing it or billowing clouds of soot? Will changing the standard exhaust make any difference? Also what VAG exhausts will fit?
Reply #5August 28, 2010, 08:25:36 am
Vanagoner
  • 219
Re: Tuning N/A 1.6D
« Reply #5 on: August 28, 2010, 08:25:36 am »
I have a 12mm head, mechanical lifter 1.6; MKII Jetta VE pump (unmodified) in a Vanagon camper.
Changing the exhaust to duals was the biggest performance upgrade I have experienced.  Makes a huge difference for me.
I think there are a lot of aftermarket downpipes that will work with your caddy.
http://www.techtonicstuning.com/main/index.php?main_page=index&cPath=2_11_4_19&zenid=0c879d654441e83cc9d2b6e84c8255e6
 The muffler I am using is not VAG, it is a welded flowmaster style.  I don't know if that would fit in your application.
Sage
Reply #6August 28, 2010, 11:57:59 am
Re: Tuning N/A 1.6D
« Reply #6 on: August 28, 2010, 11:57:59 am »
or, you could use the sweetest exhaust manifold ever.. the Garrett VNT! they rock.. but then you would be boosted. and i think you dont want that..
