Author Topic: Found my next project  (Read 5760 times)
August 26, 2010, 07:54:07 pm
« on: August 26, 2010, 07:54:07 pm »
This is great. Jeremy, see what you can do once you get a welder LOL. If I had tons of play time I would do something like this. The only bad deal *from personal experience* is that he should wait until the oil is done draining past the rings before starting again. It is hard on the rods.
VW Rollgolf testdrive
Reply #1August 27, 2010, 08:21:33 am
honda_is_the_best
  • 104
Re: Found my next project
« Reply #1 on: August 27, 2010, 08:21:33 am »
i doubt he is worried about the rods  ;)
VW it aint just a car, its a way of life..... Boost, Soot, Repeat
Reply #2August 31, 2010, 08:08:26 am
« Reply #2 on: August 31, 2010, 08:08:26 am »
poor front struts :P that car with that bar off, would be wicked!
Like take a four door golf (so you have short front doors) and take the hatch right up to behind the seats. Then lower it a tad and put a really good suspension in it. You could out handle a mini downtown NY :P
Yes Lucas, my plans are actually a 5hp snow-blower engine on a bicycle with a belt clutch from a Polaris ATV :P
Reply #3August 31, 2010, 08:17:57 am
GEE-BEE
  • 1604
« Reply #3 on: August 31, 2010, 08:17:57 am »
I finally found the right car for my son...
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4August 31, 2010, 04:39:15 pm
redneck_vdub
  • 80
« Reply #4 on: August 31, 2010, 04:39:15 pm »
That is just pure awesomeness ! :D
'01 Golf TDI "The Redneck V-Dub"
360,000kms on the body; 17,000kms on the engine :D
EGR delete, 2.25" turbo back, air box mod, Giles injectors, VNT 17, ARP headstuds, 14LB flywheel, boost and EGT gauges.
Oo=w=oO
Reply #5August 31, 2010, 05:13:06 pm
Grey_Smoke
  • 83
    fling wing for the win.
« Reply #5 on: August 31, 2010, 05:13:06 pm »
will be interesting to see what he does next.  :P
2001 TDI
86 Jetta Coupe TD - Still going together
sold - the Gutless wonder - 97 AAZ
An Oldvolks Home
Reply #6September 01, 2010, 08:29:11 am
« Reply #6 on: September 01, 2010, 08:29:11 am »
Actually a guy built an A2 Golf like that without the roll part-
http://forums.vwvortex.com/showthread.php?4869465-I-give-you-MINI-HORSE
For some reason some of the pics aren't working... but one that I found:
I think it's pretty sweet and very well done!  Actually a work in progress so I guess it's not "done" yet...
