Author Topic: SOLD: Wake up your AAZ with a Giles pump  (Read 6642 times)
August 25, 2010, 07:49:57 pm
« on: August 25, 2010, 07:49:57 pm »
AAZ Giles pump for sale:
Full Giles makeover, new seals, etc.  Has less than 20K km on it... loved what it did to my MK3 but I have a TDI project in the garage so this puppy needs to find a good home.  $750 + shipping from Edmonton Alberta Canada T6H 1E2, no return core required.
« Last Edit: September 03, 2010, 09:48:26 am by Vincent Waldon »
Reply #1August 26, 2010, 03:14:56 pm
wpinnix
  • 49
Re: Wake up your AAZ with a Giles pump
« Reply #1 on: August 26, 2010, 03:14:56 pm »
I'm curious if this will accept the adjustable pulley that came on later AAZ's?
Reply #2August 26, 2010, 09:06:16 pm
Syncroincity
  • 727
« Reply #2 on: August 26, 2010, 09:06:16 pm »
Bump for a great price, these are $1200+ from Giles to build one from an eco AAZ pump.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #3August 26, 2010, 09:34:43 pm
« Reply #3 on: August 26, 2010, 09:34:43 pm »
Thanks... they are at that.  I have my own version of a hopped-up pump in the car at the moment... but no comparison from a power or smoke-management perspective.... just ask the tailgaters behind me.   ;)
You could PM Burn_your_money to confirm... hell, he probably *built* that pump...but I suspect it could work.  The pump doesn't have the hole in the body for the locking pin and the shaft locking bolt on the side (so setting up the initial TDC timing would be a little tricky) and the mounting holes are slotted so a bit of thinking would be required to mount it straight, but I believe the pulley shaft tapers are the same.  The nose on this pump is *smaller* than the nose on the adjustable pulley style so at least it won't need the mount and timing belt cover plate swapped.  BTDT.
The adjustable pulley *is* a treat for sure... unless you like to time by ear with the engine running.  ;D
« Last Edit: August 26, 2010, 09:46:56 pm by Vincent Waldon »
Reply #4August 28, 2010, 06:35:35 pm
« Reply #4 on: August 28, 2010, 06:35:35 pm »
Vince pretty much covered what would be required to put an adjustable pulley onto this. If you have a pump with an adjustable pulley installed on the car now you will need the proper pump mounting bracket.
You will need the right timing belt backing plate or you can modify yours.
Reply #5August 31, 2010, 04:50:26 pm
somedumbjerk
  • 71
« Reply #5 on: August 31, 2010, 04:50:26 pm »
shame it's not for my 1.6  >:(
Reply #6September 02, 2010, 10:55:20 am
Sam Johnson
  • 55
« Reply #6 on: September 02, 2010, 10:55:20 am »
Vincent,
My engine is the old style 1.9 AAZ, the IP pulley is not adjustable, so I assume this should just bolt right on.
Please send a PM to me with the total cost of the Giles pump including shipping to Tucson, AZ (85750).   With regard to shipping speed is not important as I do not plan to install it until sometime in October.  Please copy the email to my other email, [email protected].  Also send your Paypal information or let me know if you need another form of payment.
Regards,  Sam
Tucson, AZ
Reply #7September 02, 2010, 11:32:18 am
« Reply #7 on: September 02, 2010, 11:32:18 am »
Will do Sam.. thanks for your interest!
Reply #8September 02, 2010, 01:10:56 pm
32 VALVES
« Reply #8 on: September 02, 2010, 01:10:56 pm »
so whats the hype with this pump, how much more power can I attain, right now I just have a regular aaz pump on my 1z with .205 nozzles, and a k04 hybrid turbo, with front mount and Im not satisfied yet oh yeah Im running 12psi
Reply #9September 02, 2010, 01:24:06 pm
« Reply #9 on: September 02, 2010, 01:24:06 pm »
The AAZ pump is designed for IDI engines, and although it will physically bolt on to a TDI engine like your 1Z it's not very compatible at all, particularly from a fueling perspective.  What you want is called an "mTDI" pump... a pump specifically designed for TDI fueling requirements but with "m"anual or non-electronic throttle.  Giles builds those as well, BTW.    ;D
You can build an mTDI pump out of an AAZ pump but lots of mods/parts are required... there's quite a few threads on this on the board, including a pretty good overview in the FAQ.
I'd also ask you to post any further questions/discussion up as a separate thread in the TDI section.. this pump (and thread) are not compatible with mTDI applications like the 1Z, and we don't want to mislead anyone.   ;)
Reply #10September 03, 2010, 09:48:06 am
« Reply #10 on: September 03, 2010, 09:48:06 am »
Sold... thanks everyone for your interest!!
