General Information
Upgrades (non engine related )
Alternative to A/C?
Topic: Alternative to A/C? (Read 4958 times)
August 25, 2010, 12:59:34 pm
ventureforth
Alternative to A/C?
August 25, 2010, 12:59:34 pm »
Have an '82 Rabbit 1.6NA. Doesn't have A/C. I was wondering if anyone has experimented with alternatives to adding OEM A/C that are lighter, less expensive, more efficient, etc. I could probably find all the parts I need for factory style A/C, but since I'm starting from scratch here I was thinking there might be a better option. Right now, I have a clip fan plugged into the lighter and the windows open. Not really helping when sitting in traffic with 100+ temps outside.
Thanks...and stay hydrated!
Last Edit: August 25, 2010, 01:08:44 pm by ventureforth
August 26, 2010, 07:37:47 pm
truckinwagen
Re: Alternative to A/C?
August 26, 2010, 07:37:47 pm »
swamp cooler.
they are way cooler.
-Owen
83 Opel Kadett Diesel
August 26, 2010, 09:50:45 pm
ventureforth
August 26, 2010, 09:50:45 pm »
For economy sake, I actually found KoolerAire. It plugs into the lighter and uses a cooler (i.e., Igloo) filled with ice or ice packs or something ice-like. Seems to work pretty well and it only cost $40 and uses very little energy and is very portable.
August 27, 2010, 08:44:41 pm
Baron VonZeppelin
August 27, 2010, 08:44:41 pm »
Show us some pix and tell us more about it when you get it.
September 23, 2010, 06:22:44 pm
ventureforth
September 23, 2010, 06:22:44 pm »
So I tried it out. Not bad for $40, but not great either. On a warm day, it may help a bit. But on a hot day, it doesn't stand a chance. I tried various amounts of ice and various forms (blocks, cubes, frozen bottles, etc.). I might say it's better than nothing, but just barely. Still, it might be good for camping or some other application, so I'm not completely unhappy with my purchase. And on a modestly warm day, I will certainly enjoy having it on board the Rabbit.
September 25, 2010, 10:18:21 am
September 25, 2010, 10:18:21 am »
thermo-electric plates?
build a a/c unit out of peltiers? i know those get ice cold on one side, and burnin hot on the other side..
the igloo a/c unit sounds a bit too much like a ice cast to me, with the ice cast removed and a heat exchanger and fan added..
there has to be something better and less ghetto than a igloo cooler..
September 26, 2010, 11:30:23 am
dennis
September 26, 2010, 11:30:23 am »
If your in a low humidity climate I vote for the swamp cooler. Some of the air-cooled guys use those. If your in a high humidity area then it just makes it harder for your sweat to evaporate.
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
September 26, 2010, 11:32:27 am
September 26, 2010, 11:32:27 am »
swamp cooler as in the kind that hangs off the side of the car, out the window?
September 26, 2010, 05:33:09 pm
dennis
September 26, 2010, 05:33:09 pm »
Yep in most cases. Just uses evaporation to cool. Regular A/C does the same thing, but the refrigeraqnt is recirculated where as water cools as it evaporates, and must be re-filled.
September 26, 2010, 08:38:27 pm
ventureforth
September 26, 2010, 08:38:27 pm »
Yeah, I was gonna go for one of those classic cooler deals that hang off the side of the window, but the place that came highly recommended was out of stock for the foreseeable future and I needed a right away solution. Plus, the KoolerAire was $40 and the swamp cooler was a few hundred dollars, so I figured I'd give the lower cost option a shot. The summer is almost over now (though today it got up to 105 or so), but I might invest in the out the window classic cooler before next summer rolls along.
September 28, 2010, 02:51:50 pm
79rabbit4dr
September 28, 2010, 02:51:50 pm »
YES!!!
Reply #11
September 30, 2010, 08:14:39 am
Reply #11 on:
September 30, 2010, 08:14:39 am »
Quote from: 79rabbit4dr on September 28, 2010, 02:51:50 pm
YES!!!
this is WIN right here...
Reply #12
October 14, 2010, 10:00:56 am
dennis
Reply #12 on:
October 14, 2010, 10:00:56 am »
That would be an afternoon Caddy upgrade. I could even strap it down in the bed and duct the air into the sliding window.
Dennis
General Information
Alternative to A/C?
