Author Topic: For Sale: AAZ engine, transmission & TON of parts *photos*  (Read 4130 times)
August 23, 2010, 01:08:24 am
fundulus
  • 2
« on: August 23, 2010, 01:08:24 am »
Engine is complete as far as I know, minus the cylinder head.
Transmission has a fresh clutch in it.
Unknown kms, I got these parts with my 93 Golf. These are from an AAZ Jetta.
$300 takes everything.
This is my loss, as I'm moving & need to get this stuff outta here.
Here are the other misc. parts that included (I may not have all the names right, I'm no pro):
> Complete Front Drive Axle w/CV Joints and disc brake assembly
> Exhaust manifold
> Shifter Linkage
> Steering Linkage
> Catalytic Converter
> Brake Booster
> Complete rear brake drums
> Complete water pump
> Washer fluid pump
> Complete Headlight/Interior Light Switches
> Trunk latch w/ wiring & keyhole
> Complete hood alarm switch
> Strut tower cover
> Complete interior brake light assembly
> Complete horn assembly
> Complete radiator fan w/motor
> Complete Washer Fluid Resevoir w/wiring
> Complete e-brake assembly w/plastic housing
> Door speaker w/connections
> Antifreeze Resevoir
> "Oh %*#" handle
> New in box side marker w/bulb
> side marker light
> Complete Antenna w/mounts & plug
> Door handle
> Power steering resevoir cap
> AAZ pulley/belt cover
> Cam Gear
> Crank Gear
> Crankshaft pulley
> Tension roller
> Muffler
> Throttle levers (engine)
> Complete AAZ throttle body w/gear
> Head gasket
> Complete Valve Cover w/cap
> Complete AAZ turbo
> Rubber Air intake tube
> Crankcase breather reg. valve w/hose
> Clear fuel tube w/ connectors
> Valve cover gasket
> Complete Air filter assembly w/both connectors
> Top & bottom plastic radiator covers
> Bag of random VW relays (25+)
> Lots of hoses
> Bunch of Suspension Springs
> Lots of belts
....and more..
Located in Peterborough
e-mail me at peterkowalski(at)trentu.ca
Cheers,
Pete
« Last Edit: August 23, 2010, 01:11:32 am by fundulus »
Reply #1August 25, 2010, 01:56:40 pm
Zukiman87
  • 65
Re: For Sale: AAZ engine, transmission & TON of parts *photos*
« Reply #1 on: August 25, 2010, 01:56:40 pm »
Do you have the fuel filter assembly and lines?
