Author Topic: Tips and Tricks for using a 11mm head on a 12 mm block  (Read 3903 times)
December 19, 2005, 09:51:41 am
Justin
  • 455
« on: December 19, 2005, 09:51:41 am »
So I am using a 11 mm diesel head on a 12 mm head bolt block and though that it would be just drill out the holes for the 12 mm bolts, upon assembly I noticed that the washers that come with the 12 mm head bolts are larger in OD than the old washers and I had to grind the washers off of the bolts and drill out the old washers to make everything fit
other than that everything went together just fine and I thought that I would let everyone know just incase they attempted this
later
Justin
www.archeryprostaffmi.com
Reply #1February 03, 2006, 12:39:36 pm
RustyRabbit
  • 33
« Reply #1 on: February 03, 2006, 12:39:36 pm »
My new rabbit has the 11 mm on 12mm set up also.  I was surprised to see that after I got her home and was poking around the engine.  All those washers!!  Is there any advantage to this set up?  Is there any danger?
Thanks.
