What should my egt's be at?
Topic: What should my egt's be at? (Read 2187 times)
August 15, 2010, 07:13:20 am
32 VALVES
August 15, 2010, 07:13:20 am »
I got a 1z, with a .205 nozzles, aaz pump, and running 11psi of boost, and 2" exhaust no muffler out the side of caddy?
I see about 600'f cruising and 1000'f wide open throttle banging through the gears...
August 15, 2010, 08:05:52 am
GEE-BEE
Re: What should my egt's be at?
August 15, 2010, 08:05:52 am »
At 75 mph: 8 psi , 725 temp
1.9 aaz
giles pump
2.5 dp and exhaust
oil temp 205
water 197/205
Iam going with a 675 mm radiator for hotter conditions
Iam on the fence for a intercooler, I dont see more than 17 psi
This truck halls ass since the ported & polished head...
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
