Author Topic: metal hg question  (Read 2155 times)
August 08, 2010, 08:29:23 am
arnold
metal hg question
« on: August 08, 2010, 08:29:23 am »
When doing the aaz metal hg upgrade on a 1.6 the gasket has a 3mm larger bore,so it creates a gap between the block deck and the cilinder head,creating uneven combustion proces.
Obviously a lot of people seem to run this upgrade without problems but i cant help questioning reliability on a daily driver ?
Reply #1August 08, 2010, 09:05:40 am
  • 1739
Re: metal hg question
« Reply #1 on: August 08, 2010, 09:05:40 am »
It's the only type that VW dealers have been using for the past ten years or so on every diesel  car. I never saw a problem.
Reply #2August 08, 2010, 11:43:22 am
« Reply #2 on: August 08, 2010, 11:43:22 am »
it creates a gap between the block deck and the cilinder head,creating uneven combustion process
Hmmm.... interesting thought I don't think anyone's considered before!
Just my personal opinion:
If you think about it in terms of the big picture, it's 3mm times perhaps .01 mm. when it's compressed, vs. the 20+ cc volume (IIRC!) of the actual combustion chamber.
Another factor to consider would be that in IDI engines combustion takes place in the pre-chamber, which from a burn perspective is a consistent volume regardless of headgasket details.
It's also worth noting that there's already a tiny circular gap on a standard 1.6l headgasket as well, to accommodate for over-sized pistons.
I guess all in all my personal opinion would be... drive more, worry less!!
