best turbo for aaz
Topic: best turbo for aaz (Read 3018 times)
August 07, 2010, 05:04:36 am
sherlockaaz
Newbie
best turbo for aaz
August 07, 2010, 05:04:36 am »
hi guys im a long time lurker here. im just lookin for opinions for best turbo for my aaz. i had a 1.6td with what i belive to be a t3 but it could only boost 1 bar and was very laggy.the aaz i have now has its standard tiny turbo but will boost 1.5bar instantly i also have just got a 1.6gtd engine with a watercooled turbo just wonderin wat they boost like?
cheers guys
August 07, 2010, 10:55:49 am
Re: best turbo for aaz
August 07, 2010, 10:55:49 am »
your T3 didnt work right if it only made 15 psi.. it should make 30 psi easy.. and be pretty laggy, but not horrible..
August 07, 2010, 11:25:44 am
August 07, 2010, 11:25:44 am »
What kind of driving do you do?
Spirited? redline? foot to the floor?
August 07, 2010, 12:15:25 pm
sherlockaaz
Newbie
August 07, 2010, 12:15:25 pm »
generally flat out
i dont understand y the t3 ddn boost as mush as the aaz turbo cause the t3 is about twice the size! the turbo was perfect and the wastegate was blocked
August 07, 2010, 12:53:26 pm
August 07, 2010, 12:53:26 pm »
The usual reasons would be:
(a) boost leak
(b) pump not delivering enough fuel to create enough exhaust heat
best turbo for aaz
