Author Topic: What grade gear oil  (Read 5958 times)
August 06, 2010, 12:15:51 pm
Robb
  • 44
What grade gear oil
« on: August 06, 2010, 12:15:51 pm »
Just wondering what grade gearbox oil I should use when replacing the oil in my 1.6td GTD Gearbox?
Thank You
Reply #1August 06, 2010, 12:35:13 pm
TITan
  • 24
Re: What grade gear oil
« Reply #1 on: August 06, 2010, 12:35:13 pm »
For the 020 it should be 75w/90.
All the info you will ever need for the 020 tranny:
http://www.brokevw.com
More specificly for now:
http://www.brokevw.com/020oil.html
1990 VW T3 Transporter - 1.7D
1984 VW Scirocco GTX
1982 VW Scirocco GTI
Reply #2August 06, 2010, 03:09:44 pm
VWCaddy
  • 85
    • VW Caddy Page
« Reply #2 on: August 06, 2010, 03:09:44 pm »
I use a GL-4 oil, typically Redline MTL in mine:
- http://www.4crawler.com/Diesel/ForSale/ShiftLinkage.shtml#FAQ20
'82 VW pickup, 1.9D engine, Missing LinkZ shift linkage
Reply #3August 06, 2010, 03:25:00 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #3 on: August 06, 2010, 03:25:00 pm »
For those in the UK, the Castrol fully synthetic stuff 75w85 GL4 is very good. Available from Halfrauds. ;D
DON'T USE GL5! Unless hearing the gentle fizz of dissolving brass is your thing! :-\
Reply #4August 06, 2010, 03:26:57 pm
wolf_walker
  • 1205
« Reply #4 on: August 06, 2010, 03:26:57 pm »
The redline is really excellent, fixes that 2nd gear crunch they all seem to get with age a lot of times.
Mentat Text Two
Reply #5August 06, 2010, 10:30:23 pm
RadoTD
  • 513
    Stage WTF
« Reply #5 on: August 06, 2010, 10:30:23 pm »
I've used AMSOIL Syncromesh (75W90 I think) in 3 trannies now (02A, 020 and a honda piece of something) and it has worked great for me. Not the cheapest stuff around but pretty reasonable for a good quality full synthetic
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #6August 08, 2010, 11:33:26 pm
Robb
  • 44
« Reply #6 on: August 08, 2010, 11:33:26 pm »
Thanks everyone, will order some this evening. Just checking it doesnt require anymore than a litre does it?
Cheers
Reply #7August 09, 2010, 02:40:46 am
« Reply #7 on: August 09, 2010, 02:40:46 am »
Read the links supplied above.. yup, it's more than a litre.  ;-)
Reply #8August 09, 2010, 05:20:38 am
smutts
  • 720
« Reply #8 on: August 09, 2010, 05:20:38 am »
Exactly 2.0 litres from dry to full, ;D
Check what gearbox you have, VW took a few years to move the fill plug to the right height for the Mk2 Golf, get it wrong and kill the box. :P
Reply #9August 09, 2010, 12:34:29 pm
BAM
« Reply #9 on: August 09, 2010, 12:34:29 pm »
Thank You
020 transmission lube spec is 1.9L for Golf/Jetta 80w90 GL4.  2L fits nice I run 75w90 Castrol full synthetic because we run it in bulk here at the shop.  I found the full synthetic shifts smoother.
Reply #10August 09, 2010, 03:18:03 pm
« Reply #10 on: August 09, 2010, 03:18:03 pm »
75w90 is the spec on the earlier 020 though just in case someone was confused.
Reply #11August 10, 2010, 11:03:34 am
Robb
  • 44
« Reply #11 on: August 10, 2010, 11:03:34 am »
Thanks very much for the links they are great, annoying can only find redline 75w90 in 950ml bottles, which would mean having to buy 3 and having a load spare at around £50 which is pretty expensive!
May take a look at the castrol stuff at halfrauds as I have a trade card so should be cheaper!
I have the dreaded 2nd gear crunching, what is the best grade oil to try and smooth the gearbox up? 75w90 or 75w85?
Im a sprayer and havnt dealt with transmission oil I must admit so thanks for the help
Reply #12August 10, 2010, 11:13:31 am
84tdrabbit
« Reply #12 on: August 10, 2010, 11:13:31 am »
theres your second gear crunch fix.. the suspended moly lube additive also cant hurt. i used it in my trans when i changed the oil. made it feel like new.
Reply #13August 10, 2010, 11:34:12 am
Robb
  • 44
« Reply #13 on: August 10, 2010, 11:34:12 am »
Yeah I did see the reply, however as I mentioned id have to buy 3 bottles of Redline as it only comes in 950ml bottles and it would end up costing a small fortune.
Is Redline the onyl oil that would fix this issue, or would Castrol also fix the issue as it is more readily available in the UK.
Thanks
Reply #14August 10, 2010, 11:50:03 am
84tdrabbit
« Reply #14 on: August 10, 2010, 11:50:03 am »
is a shot glass full of oil really something worth worrying about? 2 us quarts is less than 2 litres.. the spec on thes trannies is 4.2 pints. or 2.1 qts. thats a little under 2 litres IIRC..
a litre is 1000ml... 950ml is pretty darn close. i wouldnt buy a whole spare jug to pour a shot glass full out of it.
ive heard that royal purple takes care of the crunch too..
