Author Topic: Cracked Head Removing Injector Pics  (Read 2645 times)
August 05, 2010, 05:18:21 pm
kevinm
  • 78
« on: August 05, 2010, 05:18:21 pm »
Has anyone had any success with a little weld on something like this? The crack does not run into the non-threaded diameter at the bottom.  This is a td head and will be seeing boost.
btw. that injector was a 5 day removal process and it still cracked.
Reply #1August 05, 2010, 08:30:48 pm
Re: Cracked Head Removing Injector Pics
« Reply #1 on: August 05, 2010, 08:30:48 pm »
That should be able to be tig welded and better than new. I have a guy that could do that easily with the head off the car.
Reply #2August 05, 2010, 08:53:09 pm
tSoG-84bit
  • 188
« Reply #2 on: August 05, 2010, 08:53:09 pm »
I've got a couple heads I want your friend to see ;-)
if he can do it for less than I can buy a prothe core, then I'll be damn tempted.
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #3August 05, 2010, 08:55:48 pm
« Reply #3 on: August 05, 2010, 08:55:48 pm »
He can weld better than me with his eyes closed. It will penatrate and the threads will need cleaned up, but yes he could weld that very easily.
Reply #4August 05, 2010, 09:01:08 pm
kevinm
  • 78
« Reply #4 on: August 05, 2010, 09:01:08 pm »
Good news! I hope someone in the Vancouver area is just as skilled at welding ad your guy is.
