Author Topic: k14 wastegate question  (Read 4123 times)
August 04, 2010, 05:19:20 am
dts67
  • 68
« on: August 04, 2010, 05:19:20 am »
I had my k14 hotside bored out to fit a 50 trim k14 from an om606 merc, I read on here the wastegate was a problem once winded in to over 18psi, iirc it was libbybaba post and he said the springs were almost completely crushed to the point the wastegate could not open. I was running 25psi ok but when I upped the fuel a little the wastegate may as well not be there, it pegs the 30psi boost gauge at full throttle :o
Question is would a boost controller solve this issue? ie wind the gate down to standard 15psi and fit a bleed valve or dawes device?
Reply #1August 04, 2010, 07:35:31 am
arsenicpants
Re: k14 wastegate question
« Reply #1 on: August 04, 2010, 07:35:31 am »
i've also read that the k14 waste gate is super finicky, and that yes, a boost controller is your best bet
also, a k14 is way out it's efficiency range at 30 psi. 15-18 should be the max
Reply #2August 04, 2010, 07:57:20 am
dts67
  • 68
« Reply #2 on: August 04, 2010, 07:57:20 am »
Cheers mate will try one and see, btw this k14 is bigger than a t3/k24 going by the measurements posted on here ;)
« Last Edit: August 04, 2010, 07:59:50 am by dts67 »
Reply #3August 04, 2010, 09:33:19 am
jack's lack
  • 275
« Reply #3 on: August 04, 2010, 09:33:19 am »
I have a spring and ball type boost controller on my K14 and it is set to 20PSI. It works really well. It is the poor little turbo that is at its limiting the potential of this setup.
here is what I did. I beaded the pipe where I cut it with my bubble flare tool I had for the brake lines.
Here it is in situ. It is positioned so that it is easy to adjust.
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
