Author Topic: shell swapping  (Read 5228 times)
August 03, 2010, 07:27:21 am
ejg3855
  • 1
shell swapping
« on: August 03, 2010, 07:27:21 am »
I have a 89 Jetta 1.6L and the shell is tired but the engine and trans run great.
I found a 90 Jetta 1.8L that has a blown motor but the shell is in really good shape.
I was wondering if there are any nuiances that I should be aware of before trying to put my motor in that shell.
Thanks Guys!!
Reply #1August 03, 2010, 09:31:47 am
  • 1739
Re: shell swapping
« Reply #1 on: August 03, 2010, 09:31:47 am »
Save most of the beers for when you're finished, otherwise it's a go!
Reply #2August 03, 2010, 06:27:43 pm
srgtlord
  • 797
Re: shell swapping
« Reply #2 on: August 03, 2010, 06:27:43 pm »
make sure the shell was not hecho en mexico, because these tend to rust in strange places. Dont ask how I know.
Reply #3August 03, 2010, 06:31:54 pm
catlin_cava
  • 1954
Re: shell swapping
« Reply #3 on: August 03, 2010, 06:31:54 pm »
The middle of the roof  ;D
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #4August 03, 2010, 08:39:00 pm
Baron VonZeppelin
Re: shell swapping
« Reply #4 on: August 03, 2010, 08:39:00 pm »
Check the tranny codes on both vehicles first.
Your 89 "should" be an AOP code - which is a great tranny.
But that was a transition year - and you might have the later one, or a swapped unit.
The gasser may have undesirable gearing - and it may have very desirable gearing. Thats why i'd check what has what.
You can compare codes-ring&pinion-5th ratio's on this site :
www.a2resource.com
Both cars will have CE2 wiring, so you're good on that.
You can put your DIESEL cluster in the dash - if wanted.
Reply #5August 03, 2010, 09:03:24 pm
Re: shell swapping
« Reply #5 on: August 03, 2010, 09:03:24 pm »
I would first verify that both cars are CE2. 89 was a change-over year IIRC
Reply #6August 03, 2010, 11:15:57 pm
Baron VonZeppelin
Re: shell swapping
« Reply #6 on: August 03, 2010, 11:15:57 pm »
i was thinking 88 was switch on wiring.
yeh - check it anyway
CE2 doesn't have an upshift indicator, and some other diffys.
« Last Edit: August 03, 2010, 11:20:24 pm by Baron VonZeppelin »
Reply #7August 06, 2010, 01:44:26 pm
Re: shell swapping
« Reply #7 on: August 06, 2010, 01:44:26 pm »
mid 87 iirc.. i think they went CE2 when they went digifart.. and CE1 was for cis-e mostly..
