Author Topic: FS: ECOdiesel Rad fans with shroud  (Read 4050 times)
July 31, 2010, 12:11:12 pm
Quantum TD
  • 1195
« on: July 31, 2010, 12:11:12 pm »
This actually came off a 1991 Jetta Ecodiesel with about 170K on it. Tested and known working fan motor with no noises.
$100 plus ship OBO
Located in Nashville, Tennessee.
If you need parts of the wiring or relays, I have that stuff too.
Pics:
« Last Edit: July 31, 2010, 12:13:18 pm by Quantum TD »
Reply #1August 01, 2010, 08:59:31 am
GEE-BEE
  • 1604
Re: FS: ECOdiesel Rad fans with shroud
« Reply #1 on: August 01, 2010, 08:59:31 am »
wiring ?$
Overall length
relay $ ?
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2August 01, 2010, 10:11:30 am
Quantum TD
  • 1195
« Reply #2 on: August 01, 2010, 10:11:30 am »
wiring ?$
Overall length
relay $ ?
GB
Overall length from mount to mount (excluding the extension) is 27 inches. It will not fit a stock MK1 radiator. It's too long. If you have a MK2 radiator, it will fit.
Wiring w/o relays: $40
Wiring w/relays: $50
