Intake Modification
Topic: Intake Modification (Read 5852 times)
July 27, 2010, 09:09:37 am
Zukiman87
Intake Modification
July 27, 2010, 09:09:37 am »
I'm starting my build on my 1.6 n/a.I was looking at the intake on it and it kinda looks inefficient the way the cold air is directed into the motor.I was thinking of eithier cutting the ducts out completely or maybe just drilling holes in them so the air gets into the motor faster.Anyone tried any modifications to their intakes?
July 27, 2010, 11:44:09 am
BAM
Re: Intake Modification
July 27, 2010, 11:44:09 am »
One of my customers has gills cut in the right fender of his GTi. I asked him if it made a difference, he didn't notice any performance gains from the gills.
July 27, 2010, 11:53:29 am
July 27, 2010, 11:53:29 am »
you can use 4" intake piping..wont hurt a thing..
July 27, 2010, 01:10:59 pm
Smokey Eddy
July 27, 2010, 01:10:59 pm »
you can draw your intake air from the rain tray. OR if you're really savy cut a hood scoop in the hood right above the intake (like on a subaru) and have the intake filter housing mate with the hole you cut in the hood with some simple fabricating. Rivit some alluminium sheet metal to the filter to raise it up to the hood (that extra inch or so you need) and weather strip around both the hole in the hood and the intake riser you make. it would obviously take more thought that that but...
that would be really cool to see
I bet at highway speeds you'd actually have possitive pressure in the intake. i'd go as far as to say even 1-2psi.
Ed
THROWN ROD
July 27, 2010, 01:17:16 pm
July 27, 2010, 01:17:16 pm »
Ed, just going by his user name, im gonna assume this engine is in a Samurai..
July 27, 2010, 01:41:53 pm
Smokey Eddy
July 27, 2010, 01:41:53 pm »
oh yeah ... didn't notice that
was too interested in the subject matter.
but no matter, you can still do that in a sami =D
Ed
THROWN ROD
July 27, 2010, 02:33:34 pm
Zukiman87
July 27, 2010, 02:33:34 pm »
Ram air is the plan guys but I'm talking about the inside of the intake behind the filter. The air has to go up and all the way down the ducts into the head. I'm gonna try cutting the ducts completely out so the air doesn't have to travel all that way to the engine. By the time it gets thereits already warmed up.
July 27, 2010, 02:44:45 pm
Smokey Eddy
July 27, 2010, 02:44:45 pm »
OOOOOooooooooo I see what you're saying. You want a more efficient manifold from the filter to the ports of the head. I see i see. WELL you can run any intake from almost any 4 cyl engine on there. Some have O shape ports and others D shape but with a tiny bit of porting with a dremel or even a file you can make it work well.
If you've got the skill and equipment to weld alluminum you could make an AWESOME intake manifold for your NA from a p190 intake (or what ever its called - the huge thick one)
Ed
THROWN ROD
July 27, 2010, 03:00:40 pm
Zukiman87
July 27, 2010, 03:00:40 pm »
P190 intake? What are they off of?
July 27, 2010, 04:55:23 pm
Smokey Eddy
July 27, 2010, 04:55:23 pm »
the newer TDI's. I think its P190 ... there are a couple variations. They are from the PD engines... maybe its PD190?
Ed
THROWN ROD
July 27, 2010, 04:58:22 pm
Smokey Eddy
July 27, 2010, 04:58:22 pm »
here is one
augh work blocks most of photo bucket so i can't copy the links ... thisi s getting to be very annoying..
here go to this page
that is one
here is the link if that didn't work
http://media.photobucket.com/image/PD%20190%20intake%20TDI/ryan-pak/Parts%20reference%20pics/Passatinlet.jpg
anyways, they are the best intake in my opinion. Big runners! but clearly designed for a turbo application so maybe if you cut the top of it off and made some sort of air box for it that mated to the hood and housed a filter?
Last Edit: July 27, 2010, 05:00:43 pm by Smokey Eddy
Ed
THROWN ROD
Reply #11
July 27, 2010, 05:33:19 pm
GEE-BEE
Reply #11 on:
July 27, 2010, 05:33:19 pm »
I have a 1Y intake and snorkel that will bolt right on
Email me at
[email protected]
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #12
July 28, 2010, 03:12:12 pm
Reply #12 on:
July 28, 2010, 03:12:12 pm »
gasoline intake manifold will work too, and if you get a mk2 manifold, the inlet will be faced the right way. then you can run a cone filter, instead of the huge paper filter.
Reply #13
July 28, 2010, 04:51:03 pm
Reply #13 on:
July 28, 2010, 04:51:03 pm »
A K&N cone filter, just because OM617 hates them
Ed, do you mean a PD150 intake??
Stupendously Awesome!
Reply #14
July 28, 2010, 05:33:42 pm
MJF
Reply #14 on:
July 28, 2010, 05:33:42 pm »
Stock paper filter is much better than any cone filters in our power levels.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Intake Modification
