Author Topic: safe egt  (Read 5359 times)
July 18, 2010, 03:37:41 pm
skifree
  • 32
safe egt
« on: July 18, 2010, 03:37:41 pm »
What the highest safe sustain egt? Also what is the highest temporary egt?
Reply #1July 18, 2010, 05:27:43 pm
RadoTD
  • 513
    Stage WTF
Re: safe egt
« Reply #1 on: July 18, 2010, 05:27:43 pm »
Probably 1200 sustained and 1500 peak. I wouldn't want to go past either of those
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #2July 18, 2010, 05:34:39 pm
Re: safe egt
« Reply #2 on: July 18, 2010, 05:34:39 pm »
literally 1500 peak for no more than 2-5 seconds as this heat will start to melt the piston crowns, valves, and head.
A turbo block and head can sustain 1350F for quite a while, but that amount of time is unknown :P So why chance it... Stay under 1200 all the time and you will be perfectly safe.
Reply #3July 18, 2010, 07:16:55 pm
OM617
Re: safe egt
« Reply #3 on: July 18, 2010, 07:16:55 pm »
1250*f is the generally accepted limit for engines with aluminum alloy pistons.
Reply #4July 27, 2010, 09:12:18 pm
commuter boy
  • 277
Re: safe egt
« Reply #4 on: July 27, 2010, 09:12:18 pm »
Y'all should quantify where those EGT's you're quoting are measured from.
Reply #5July 27, 2010, 09:39:18 pm
Re: safe egt
« Reply #5 on: July 27, 2010, 09:39:18 pm »
Pre turbine.
Reply #6August 01, 2010, 03:34:28 pm
skifree
  • 32
Re: safe egt
« Reply #6 on: August 01, 2010, 03:34:28 pm »
Ditto
Reply #7August 01, 2010, 03:59:56 pm
Alleslowbuged
  • 270
Re: safe egt
« Reply #7 on: August 01, 2010, 03:59:56 pm »
Hi,
sounds i bit conservativ or?
In my bmw 524td the egt goes up to 1800°F, when i pull it hard through three or four gears.
In the higher gears i use the egt gauge as shiftlight, when the temperature goes above 1650°F,
so the 1800°F will be only for less than one second.
As i know the stock egt for that bmw engine under full load is 1470°F and also the stock tdi egt
from the actual engines (with 24 psi boost) are in that range.
Best Regards
VW Golf Mk1 (Typ 17) 1981 with 1.6 TD
BMW E28 524 TD
Reply #8August 01, 2010, 04:33:50 pm
skifree
  • 32
Re: safe egt
« Reply #8 on: August 01, 2010, 04:33:50 pm »
Have you ever heated a piece of metal red and then hit the oxygen? It
would not look pretty in my engine.You must have pistons made of berylluim. Where is the probe located in the engines you are talking about.
Reply #9August 02, 2010, 10:21:16 am
Re: safe egt
« Reply #9 on: August 02, 2010, 10:21:16 am »
Hi,
Best Regards
1800*f and you arent blowing chunks of piston or rings out the tail pipe? wow..
Reply #10August 07, 2010, 02:52:30 pm
Alleslowbuged
  • 270
Re: safe egt
« Reply #10 on: August 07, 2010, 02:52:30 pm »
Hello,
for clarification, i did not drive constant 1800°F as egt in my old bimmer, this is the max peak temperature which occurs for less than an second, when i pull it hard through all gears from 1. to 4. gear.
No metall part has 1800°C to that time, because there is not enough time for all solid parts to take the energy from the exhaust gas.
The sensor is installed upfront the turbo in the exhaust manufold.
Best Regards
Alleslowbuged
BMW E28 524 TD
