Author Topic: WTB: B3 AAZ Intrument Cluster  (Read 4150 times)
July 17, 2010, 08:50:23 am
Big Daddy Roth
  • 298
« on: July 17, 2010, 08:50:23 am »
I'll need the wiring to the fuse panel as well please.
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #1July 26, 2010, 10:58:28 am
alphawerks
Re: WTB: B3 AAZ Intrument Cluster
« Reply #1 on: July 26, 2010, 10:58:28 am »
I will have both a cluster and a fusebox in a few weeks from a b4 with a 1z. close enough?
If so, what are they worth to you?
Ryan
Reply #2July 26, 2010, 11:57:21 am
CdnVWJunkie
  • 309
« Reply #2 on: July 26, 2010, 11:57:21 am »
AAZ speedos uses a cable drive while the 1Z uses a VSS= no worky!
FYI: A T4 Eurovan or Transporter diesel uses the same cluster if that helps your search.
Reply #3July 26, 2010, 02:52:34 pm
« Reply #3 on: July 26, 2010, 02:52:34 pm »
There is a cluster 11 threads down for an aaz ???
http://www.vwdiesel.net/forum/index.php?topic=26254.0
Reply #4July 26, 2010, 05:18:16 pm
Big Daddy Roth
  • 298
« Reply #4 on: July 26, 2010, 05:18:16 pm »
I have one from a Eurovan. Yes, it will work. But I want one for a Passat please.
1993 TD B3 Sedan
