Author Topic: vnt control = dawes valve  (Read 16778 times)
July 13, 2010, 02:45:33 pm
55eta
« on: July 13, 2010, 02:45:33 pm »
Just wondering if anyone have used the dawes valve vnt controller sold by 3barr racing as it looks like a very simple set up and cheap product
Reply #1July 14, 2010, 12:54:05 am
Re: vnt control = dawes valve
« Reply #1 on: July 14, 2010, 12:54:05 am »
Retail on the valve is $14 at Mc Master Carr or Grainger.
Reply #2July 14, 2010, 02:54:47 pm
55eta
« Reply #2 on: July 14, 2010, 02:54:47 pm »
Thanks,but was looking for some feed back on the performance of them as i have seen a few posts on other forums that are a bit conflicting ,some have done away with the ecu control in favor of the dawes valve and claim a much flatter boost curve than the ecu control but others agree with the smother boost curve but reckon they produce a higher boost at cruising speed ,which in my eyes cannot be good for the longevity of the turbo.but the simplicity and adjustability of them when used with a needle valve is what interests me but i am still sceptical ,can something that simple produce such good control/performance?
Reply #3July 14, 2010, 03:04:53 pm
55eta
« Last Edit: July 14, 2010, 03:11:44 pm by 55eta »
Reply #4July 14, 2010, 08:25:00 pm
Syncroincity
  • 727
« Reply #4 on: July 14, 2010, 08:25:00 pm »
That Dawes-controlled boost map looks like you're waiting for a long time for boost to build up...gutless bottom end. I thought one of the attractions of the VNT was the ability to build high boost levels early in the RPM range?
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #5July 15, 2010, 02:12:42 am
55eta
« Reply #5 on: July 15, 2010, 02:12:42 am »
Yes looks a bit that way i think that's where the criticism on other post i read came from{but sounded like a boy racer posted it} ,if you want high boost at low rpm you can achieve it but the trade of is high psi at cruising speeds that's why i am looking to see if anyone has used them just to get a clearer view of there performance ,the one in the link is on a big 4+4 and a flat boost curve would be a good thing off roading boost spikes=wheel spin .so still waiting to hear from someone who have used them in a daily drive as i have a vnt but don't want to go to the trouble off fitting it{the vnt} only to find out they are $hit {the valve}
Reply #6July 15, 2010, 04:48:46 pm
Syncroincity
  • 727
« Reply #6 on: July 15, 2010, 04:48:46 pm »
Yeah, I'll be watching as well. I have experience with manual boost controllers on my Subaru, (non-vnt) I'm curious about the Dawes setup, never heard of it before.
JC McCavitt
'98 Jetta Wolfie
Reply #7July 18, 2010, 09:10:49 am
OM617
« Reply #7 on: July 18, 2010, 09:10:49 am »
A single valve alone will not work for a VNT. You need multiple stages to limit boost by engine load.
Reply #8July 18, 2010, 02:08:22 pm
55eta
« Reply #8 on: July 18, 2010, 02:08:22 pm »
If you look at the system in the link in the 4th post, there are two valves one to control vacuum{needle valve} which operates the vnt control cylinder and the Dawes valve, which is boost controlled which controls the vacuum supply to the control cylinder to me it seems like it has a infinite amount of stages?but like i have said in earlier posts im looking for some feed back from some one who have used one on a daily driver
« Last Edit: July 18, 2010, 02:10:10 pm by 55eta »
Reply #9July 18, 2010, 02:34:58 pm
OM617
« Reply #9 on: July 18, 2010, 02:34:58 pm »
No, it doesn't quite work that way. The needle valve will flood the vacuum system with air and make the other vacuum consumers inoperable.
Reply #10July 18, 2010, 03:28:22 pm
55eta
« Reply #10 on: July 18, 2010, 03:28:22 pm »
I can see where you are coming from but don't think that to be the case as i have read a couple of post which have give conflicting view's of the valve but none to suggest that ,also the link says you can use the ecu control combined with it which would include the N75 valve which is a electronically controlled vacuum valve.by the the way the the link is not from the manufactures of the valve but a australian off road er just using the product ,so there is no vested interest trying to sell something .The way I'm thinking at the moment is there has to be something in it for him to make a perfectly good ecu controled unit redundant in favor of it
Reply #11July 18, 2010, 07:09:44 pm
OM617
« Reply #11 on: July 18, 2010, 07:09:44 pm »
The dawes device when used with the standard ECM is not for primary control of boost, its to prevent boost spikes caused by the computer's natural time lag.
Reply #12July 19, 2010, 11:36:25 am
55eta
« Reply #12 on: July 19, 2010, 11:36:25 am »
So what its purpose when no ecu is used? is it there just to make all the other vacuum consumers inoperable as a single valve cannot control a vnt?
Reply #13July 24, 2010, 02:35:52 pm
OM617
« Reply #13 on: July 24, 2010, 02:35:52 pm »
Its not used without the ECU.
Reply #14July 26, 2010, 09:59:14 am
« Reply #14 on: July 26, 2010, 09:59:14 am »
Correct, it should be noted that the dawes device is not a VNT controller.
