Author Topic: Running Cooler 1.9 AAZ ( Coolant Temp ) hose upgrade  (Read 3015 times)
July 13, 2010, 07:56:22 am
GEE-BEE
  • 1604
« on: July 13, 2010, 07:56:22 am »
I checked my temp ( coolant )and after installing the one piece design silicone engine hoses my temp are down 15 to 22 degree's.
The plastic T fitting the connects the three hoses together was causing some flow restrictions.
My new production is a one piece design
Iam sure the 5 ply design will be the last set.
Let me know if you would like a pic
[email protected]
The install was easy , I did remove the alternator and bracket after draining the coolant, while i was there i did replace the two o'rings on the crank breather.
This is where my tiny leak was at.....
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1July 14, 2010, 03:32:36 pm
Re: Running Cooler 1.9 AAZ ( Coolant Temp ) hose upgrade
« Reply #1 on: July 14, 2010, 03:32:36 pm »
« Last Edit: July 14, 2010, 04:14:30 pm by theman53 »
Reply #2July 14, 2010, 03:57:05 pm
wolf_walker
  • 1205
« Reply #2 on: July 14, 2010, 03:57:05 pm »
I've always sort of wanted a diesel to run as warm as possible and be safe.  They seem to run better, cleaner and get better MPG/power.  I'd just noticed last week I put an 80C t-stat in for instance, and with the correct 87C the thing runs much better.  The difference in the two is quite apparent on the gauge.  Just  a thought.
Mentat Text Two
Reply #3July 14, 2010, 06:18:10 pm
GEE-BEE
  • 1604
« Reply #3 on: July 14, 2010, 06:18:10 pm »
I start seeing coolant temp's around 200 plus at 75/80 mph
10 psi / 765 egt
MK1 caddy with a/c type radiator, next will be a 16 v scirocco type with dual electric fan's
My Mcnally gauges dont lie....
My local wrench says the #1 problem is the plastic t fitting ( chinese made ) on coolant hose assy's
There even in a German meyle box...
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #4July 16, 2010, 01:44:22 pm
TurboJ
  • 661
« Reply #4 on: July 16, 2010, 01:44:22 pm »
Where can you get a 80 C thermostat? I would really like to have a handful of those. I can't seen to find any, anywhere.
For the high-hp tuned IDIs a cooler t-stat would be really useful, to preserve the cylinder head.
Jetta II 1.6 TD 'Project 200'
Reply #5July 16, 2010, 03:00:23 pm
Reply #6July 17, 2010, 09:17:06 pm
wolf_walker
  • 1205
« Reply #6 on: July 17, 2010, 09:17:06 pm »
I've seen stupid high oil temps on turbo's running hard, but never seen the coolant gauge budge.  Weird.  Those oil temps though, we put a huge thermostatically controlled oil cooler on the 1.9L TD in the 82 Caddy years ago, fixed it right up.
Mentat Text Two
