Author Topic: Tell Me About 1.5 Engines....  (Read 2808 times)
July 13, 2010, 04:38:22 am
rs899
  • 647
« on: July 13, 2010, 04:38:22 am »
I know some of you guys have them.  I am not interested in speed.
What are the differences between them and the 1.6D?  IIRC its the crank, pistons and rods, right?
I already have a set of remachined 1.7 gasser rods (are they used on the 1.5D)?  Are there any (other) common parts with the 1.6/1.7 gasser engine?
If I can find a 1.5 crank and pistons, can I get it to play in my 12mm 1.6 block?
What am I overlooking?
Rick
Reply #1July 13, 2010, 08:22:14 am
Re: Tell Me About 1.5 Engines....
« Reply #1 on: July 13, 2010, 08:22:14 am »
im pretty sure that 1.5 rods are not 1.7 gasser rods.
and good luck finding 1.5 pistons. they are made from unobtanium..
Reply #2July 13, 2010, 08:55:22 am
rs899
  • 647
« Reply #2 on: July 13, 2010, 08:55:22 am »
According to this:
http://cgi.ebay.com/ebaymotors/AUDI-VW-CONNECTING-RODS-WATER-COOLED-ENG-GAS-DIESEL-_W0QQcmdZViewItemQQhashZitem3a5cccf094QQitemZ250665037972QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
they are ( not that I would trust an ebay seller).  I can measure the gasser set I have and look in my old Diesel Bentley and compare the wrist pin and con rod bearing size, but that probably won't tell me that the rod itself is the same.
There's a new 1.5 crank and pistons on ebay now...the pistons I'm not so sure if they are stock or O/S.  Seems like I have seen NOS on ebay from time to time...
Reply #3July 13, 2010, 09:00:48 am
« Reply #3 on: July 13, 2010, 09:00:48 am »
im pretty sure that 1.5-1.7 gassers DO NOT ALL USE THE SAME ROD.. i dont see how they could? they have different strokes and all that fun stuff..
i could be wrong..
Reply #4July 13, 2010, 09:23:45 am
rs899
  • 647
« Reply #4 on: July 13, 2010, 09:23:45 am »
Here's another reference to the CK diesel and EN gasser using the same rod... again not sure.  Where is that ETKA site...?
http://www.rpmrons.com/VolksRods.html
Reply #5July 13, 2010, 10:52:51 am
« Reply #5 on: July 13, 2010, 10:52:51 am »
MK1GOD (or something like that) on vortex has a NOS set of standard 1.5 pistons FWIW
Reply #6July 13, 2010, 02:36:52 pm
« Reply #6 on: July 13, 2010, 02:36:52 pm »
maybe the same dimensions but a different rod
Reply #7July 13, 2010, 03:08:43 pm
UnderPSI
  • 109
« Reply #7 on: July 13, 2010, 03:08:43 pm »
1.5 rods have a 22mm wristpin.
« Last Edit: July 13, 2010, 03:31:01 pm by UnderPSI »
Suzuki Samurai 1.6
Reply #8July 13, 2010, 04:17:55 pm
rs899
  • 647
« Reply #8 on: July 13, 2010, 04:17:55 pm »
I just measured the wristpin bushings on these gasser rods- 22mm.  I checked the rod bearings and they use the same ones as the 1.5D.  Question is the length and the actual construction .
Reply #9July 13, 2010, 05:41:22 pm
UnderPSI
  • 109
« Reply #9 on: July 13, 2010, 05:41:22 pm »
1.5d and gas motors use the same rods.
Suzuki Samurai 1.6
