10 Pounds of boost and 1100 degree EGTs
Topic: 10 Pounds of boost and 1100 degree EGTs (Read 2172 times)
July 12, 2010, 02:55:17 pm
camboscams
July 12, 2010, 02:55:17 pm »
Well put on a new Giles pump timed it to .85 per his instructions and started our 1900 mile journey and did fine until the last 150 miles. I was going down a steep grade and once i got back on the flats i noticed that i could hardly put my foot in it and the egts were through the roof. I used to pull 13 pounds and be able to stay there awhile but now by the time the boost builds its at like 1300 or so. I figured it jumped a tooth of time as it did before. but everything is still spot on. So at this point i'm lost. it doesn't act like it lost an injector but theres no way to tell without pulling them and testing. So any input would be great
Thanks, Cambo
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
July 12, 2010, 09:06:14 pm
Baron VonZeppelin
Re: 10 Pounds of boost and 1100 degree EGTs
July 12, 2010, 09:06:14 pm »
Call Giles tomorrow for the best advice.
He gives full customer support/service after the sale.
July 13, 2010, 06:55:47 pm
camboscams
July 13, 2010, 06:55:47 pm »
no i can still pull full boost which is 13, but i can barely hit it cause it spikes my egts up so fast, its in the high 1300's and low 1400's in no time. But thats what gets me, it changed all at once.
July 13, 2010, 07:52:51 pm
rabbitman
July 13, 2010, 07:52:51 pm »
It might be a small enough boost leak that it can still get there but takes more heat to do it.
July 14, 2010, 06:22:06 pm
camboscams
July 14, 2010, 06:22:06 pm »
Hmmm.... good point, i'll have to investigate that. In thinking about it, it does make sense something coulda come loose when i was pulling the grade and i may have not noticed it. Thanks fellers! i hope that is the issue
