Author Topic: need a rebuil able 1.6 na head  (Read 3787 times)
July 11, 2010, 12:28:46 pm
pyro7890
  • 47
« on: July 11, 2010, 12:28:46 pm »
i have a poor 1981 rabbit, that i paid 1,100 for and drove it home 50 miles without any problems. i knew that it had a warped head because there was oil in the coolant reservoir, i figured it would be a relativity cheap and easy fix but i sent the head in to a trusted vw head specialist and he said it is not rebuild able. can anybody help me out? or dose anyone know of somewhere to get a good bare head. thanks
Reply #1July 11, 2010, 12:32:04 pm
pyro7890
  • 47
Re: need a rebuil able 1.6 na head
« Reply #1 on: July 11, 2010, 12:32:04 pm »
sorry i did not mention a mechanical 1.6 head
Reply #2July 11, 2010, 02:55:43 pm
Familydiesel
  • 154
« Reply #2 on: July 11, 2010, 02:55:43 pm »
Is it a 12mm or 11mm head (headbolt size)?
I have 11 mm heads, but no 12 mm.
1980 Diesel td pickup, Love that Diesel!
Reply #3July 11, 2010, 06:00:45 pm
pyro7890
  • 47
« Reply #3 on: July 11, 2010, 06:00:45 pm »
it is a 12mm but it could just be drilled out. how much would you want for it? is it in salvageable condition?
Reply #4July 11, 2010, 07:59:09 pm
Familydiesel
  • 154
« Reply #4 on: July 11, 2010, 07:59:09 pm »
First, I checked the heads I have and compared the 11mm and 12mm bolts and ability to fit the head.  You will not only need to drill for the bolts, but also for the larger washers; unless you use 11mm ones that you drill out to fit the 12mm bolts.
Second, I have two heads, but one that looks to me to be more rebuildable.  Unfortunately, I am not a machinist, but it doesn't look to have any water leaks and the cracks between the valves are minimal.  It has all but one valve installed, and has the matching cam caps.  Also, the prechambers are without any cracks that I can see with a magifying glass and light.   $50 plus shipping, with the understanding that I don't know if there are other cracks that I cannot see without taking it to a machine shop.  So, it is a bit of a gamble on your part, thus the $50. What is your zip, and I'll try to give you a figure for shipping.
Let me know if you still want to go this route.
Reply #5July 11, 2010, 08:02:39 pm
Familydiesel
  • 154
« Reply #5 on: July 11, 2010, 08:02:39 pm »
Also, did you check out ObscuredByClouds post of a head for sale a bit down the list of things for sale?
Here is the thread  http://www.vwdiesel.net/forum/index.php?topic=24411.0.
Hope this helps.
Reply #6July 11, 2010, 08:30:26 pm
pyro7890
  • 47
« Reply #6 on: July 11, 2010, 08:30:26 pm »
oh well if it is that much trouble nvm thanks alot for the help i think obscured by clouds has a head i can use
diesel forever woo hoo!!!!!! thanks again
