Author Topic: bad injection pump?  (Read 3667 times)
July 11, 2010, 08:03:51 am
dslwesty
  • 26
bad injection pump?
« on: July 11, 2010, 08:03:51 am »
so, i bought a resealed pump off a guy here on vwdiesel. i went to go install it on my TD vanagon. i had a running pump on it before, but it was an n/a pump. excited to put a turbo pump on, i put it on, set it all up, and used a mighty vac to pull fuel through the return line. i then pulled fuel thought he return lines on the injectors. after a bunch of cranking, i still am not getting fuel out of the cracked injectors. nothing. not a dribble, spit, or anything at all. i verified the solenoid was working and even swapped it for the one on my old pump which was running just a couple of hours previous. am i off base to think this pump is no good? i can't come to any other diagnosis! i've primed other pumps and always gotten fuel to the injectors. any other thoughts?
Reply #1July 11, 2010, 11:21:57 am
Re: bad injection pump?
« Reply #1 on: July 11, 2010, 11:21:57 am »
did you hold it at wide open throttle while trying to get the inj lines to prime? the fuel screw or idle speed screw might be set too low..
Reply #2July 11, 2010, 08:05:26 pm
dslwesty
  • 26
« Reply #2 on: July 11, 2010, 08:05:26 pm »
i did. i eventually put my original pump back on and it only took a couple of cranks to fire up. and i had drained it upon removal. i am pretty sure this new pump is faulty.
Reply #3July 12, 2010, 10:01:12 am
« Reply #3 on: July 12, 2010, 10:01:12 am »
pretty sure?
i thought my TD pump was bad too. turned the fuel screw in about 3 turns, and messed with the idle till it ran. it was fine.
honestly tho, now that i have had 2 different engines, with the same turbo and boost levels, but with different pumps, i honestly like the n/a pump better than the TD pump with the LDA on top. it spools my turbo faster. i dont mind the small puff of grey when i crack the throttle open, because right after that puff of grey, the turbo is goin..
« Last Edit: July 12, 2010, 10:02:50 am by Rabbit on Roids »
