Author Topic: Engine Removal HELP! (Audi 5000 TD)  (Read 2155 times)
July 08, 2010, 09:54:44 pm
colectb
  • 93
« on: July 08, 2010, 09:54:44 pm »
Hi, short story is that I'm pulling out a seized block from a good body. The problem is that with the automatic you're supposed to unbolt the torque converter before pulling the engine. Well that's impossible with a seized engine. The pilot shaft (as it i think it's called) is coming with the engine when I pull it away from the transmission. Would anyone  have any suggestions as to what I should do? I really don't want to pull the transmission as well.
Thanks!
1986 Porsche 944 NA
1983 Audi 5000 Turbo Diesel
Reply #1July 08, 2010, 10:13:35 pm
rabbid79
  • 684
Re: Engine Removal HELP! (Audi 5000 TD)
« Reply #1 on: July 08, 2010, 10:13:35 pm »
This probably won't help, but a few years ago I removed a 5000 TD engine and didn't realize that I needed to remove the 3 bolts on the torque converter.  I was able to do this because I used a Kubota to actually lift the engine out of the car.  Anyway, are you sure there's no way to turn the engine over with a huge breaker bar or something?  Maybe loosen/remove the main bearing caps to loosen up the crank?
'15 WRX
Reply #2July 09, 2010, 10:56:24 am
« Reply #2 on: July 09, 2010, 10:56:24 am »
just pull it straight out of the trans with the converter still attached. it only has to come out of the trans about 4 inches or so. then take the TC off with the engine in the car.
Reply #3July 10, 2010, 11:05:00 am
colectb
  • 93
« Reply #3 on: July 10, 2010, 11:05:00 am »
I got it, thanks.
1986 Porsche 944 NA
Reply #4July 10, 2010, 11:07:38 am
« Reply #4 on: July 10, 2010, 11:07:38 am »
how did you end up doing it? freeing up the engine? or pulling it out with the TC still attached?
