Author Topic: ARP main install  (Read 2938 times)
July 08, 2010, 08:48:18 pm
gnavs
  • 340
ARP main install
« on: July 08, 2010, 08:48:18 pm »
So I've just finished hand threading my ARP mains into my AAZ block and have an issue.  When the cap is placed over the stud there isn't enough thread left protruding from the top to thread the nut onto.  I used the 204-5402 kit which I assumed was the right one, all of the old posts I searched confirmed this.  At this point I'm wondering if I can just back the studs out until I have enough meat to work with or if I need to look at other bolt options?
Anders
Reply #1July 09, 2010, 08:14:14 am
Re: ARP main install
« Reply #1 on: July 09, 2010, 08:14:14 am »
If I recall someone said that the aaz had 2 different lengths of main bolts. I could be wrong as I haven't ever actually seen an aaz, but I think it was around a 20mm difference.
Reply #2July 09, 2010, 08:16:56 am
« Reply #2 on: July 09, 2010, 08:16:56 am »
found it
There is 2 different main bolts used in aaz. M10x65 same as 1,6 and newer M10x80. Also there is 2 different con rod bolts, M8x1x42 and M8x1x45. 45mm bolt centers the cap in rod.
from MJF in smoking eddy's thread.
Reply #3July 09, 2010, 08:24:23 am
gnavs
  • 340
« Reply #3 on: July 09, 2010, 08:24:23 am »
well fcuk me, I wish I would have seen this sooner.  I really just feel like cursing right now.
Reply #4July 09, 2010, 05:59:49 pm
kaneb
  • 164
    • www.dasdubbers.org
« Reply #4 on: July 09, 2010, 05:59:49 pm »
no doubt!!! that is the sucketh.
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #5July 09, 2010, 10:36:31 pm
« Reply #5 on: July 09, 2010, 10:36:31 pm »
I can get you 12.9 SHCS in m10x80 for a lot less than your ARP cost and you could sell the ARP online then and make a little cash back. Let me know.
Reply #6July 11, 2010, 12:29:44 pm
  • 3468
    • McScrubbins Body Wash
« Reply #6 on: July 11, 2010, 12:29:44 pm »
x2
theman53 is THE MAN. he can hook you up. mad props to him for he has helped me on more than 1 occasion.
Reply #7July 11, 2010, 08:52:15 pm
gnavs
  • 340
« Reply #7 on: July 11, 2010, 08:52:15 pm »
sounds good, hope to have this damn thing built before it hits its one year anniversary ;)
