Author Topic: FS 1992 2dr jetta diesel for parts  (Read 4295 times)
July 04, 2010, 06:24:00 pm
vegged-out
  • 40
« on: July 04, 2010, 06:24:00 pm »
In Victoria BC .  I am taking out the WVO system to re-install in my daughters' 1995 jetta. This car was mine out east before my daughter brought it out to BC so the body is rusted . 380+k km. many new parts alternator and bracketry, brakes, tire etc.s. IP doesn't appear to leak but the engine is leaking oil.It Havent had time to diagnose will start but runs like s#t and belches smoke . Don't want much but would like to get it taken away after I get what I need from it for her 95. Otherwise I will take the head, IP, turbo, alt, etc back to Ontario, and get Malahat to take it away. Please someone save me that work!
I noticed there is someone on the list from East Sooke. and others from Vic .  Leave me a  post or call my cell 613 391 2324.
Michiel,
Reply #1July 09, 2010, 08:22:27 pm
CathodeRayTube
  • 37
Re: FS 1992 2dr jetta diesel for parts
« Reply #1 on: July 09, 2010, 08:22:27 pm »
could the sh!tty running and smoke belching be a result from running WVO in it? I plan to run mine on WVO when i get it put together...but i want to make sure i do it right to avoid problems such as yours if that is indeed the case...
Reply #2July 11, 2010, 07:36:45 pm
vegged-out
  • 40
« Reply #2 on: July 11, 2010, 07:36:45 pm »
I have started to pull the engine apart to salvage good parts and it seems that it ran ***ty because the timing belt jumped a tooth. Head is good but every piston has just the slightest valve kiss!
Grease is not an issue as long as it is clean, dry, and hot in a hot engine. i.e. a two tank system with heat exchanger.
Car and parts still available in Victoria B.C.
Michiel
Reply #3July 26, 2010, 07:44:09 am
Helliouse
  • 164
« Reply #3 on: July 26, 2010, 07:44:09 am »
How much for the Injection pump, and mounting plate?
1990 Jetta TD...Its a Project! And wait...its built in Wolfsberg! swEEt - 1.6l TD = Dead... TDI ALH in the works...
Reply #4July 26, 2010, 04:43:49 pm
vegged-out
  • 40
« Reply #4 on: July 26, 2010, 04:43:49 pm »
The parts are in Victoria and I won't be back and able to send them 'til September.
$180. for the IP if you want to wait. Sorry, the bracket went with the block to the wreckers.
Michiel
