General Information
Troubleshooting
81 Rabbit crawls and then sputters to a stop
Pages:
Topic: 81 Rabbit crawls and then sputters to a stop (Read 6461 times)
Reply #15
July 01, 2010, 07:11:32 am
Re: 81 Rabbit crawls and then sputters to a stop
Reply #15 on:
July 01, 2010, 07:11:32 am »
Yeah it's just like Lucas said. How much fuel do you have in the tank right now?
Use a bright light and shine it in there to assess the condition of the tank.
I believe that when you remove the sender the pre-filter stays at the bottom of the tank you you need to use an extra long pair of needle nose pliers to remove it.
Have a plastic bag or pail handy to put the sender in when you pull it out.
Reply #16
July 01, 2010, 11:08:12 am
tkisling
My Bunneh
Reply #16 on:
July 01, 2010, 11:08:12 am »
I got the sender off and saw that there was a cylindrical shaped filter sitting in the tank. it was just laying off to the side inside the top portion of the tank.
Reply #17
July 01, 2010, 06:58:12 pm
tkisling
My Bunneh
Reply #17 on:
July 01, 2010, 06:58:12 pm »
Does the filter slide into the circular hole on the black opening in the tank?
Reply #18
July 02, 2010, 07:14:04 am
Reply #18 on:
July 02, 2010, 07:14:04 am »
I've never pulled the screen out so I don't know. Try in the mk1 forums on vwvortex.com
Reply #19
July 02, 2010, 07:25:53 am
rs899
Reply #19 on:
July 02, 2010, 07:25:53 am »
Yes, the filter just slides down into that black hole and seats somehow. This assumes that the diesel is like my old Cabriolet (which it seems to be). Is the tank rusty? Is there a lot of mung in the tank? The gasser tanks are notorious for rusting (mine did) , not sure about the diesels. You can buy a replacement Taiwanese one for not too much money, considering the problems a rusty one would cause you.
'91 Jetta 1.6 NA, '82 Caddy 1.6NA, '81 Cabriolet, 4 Mercedes OM616/617s , 2 Triumphs and a Citroen DS19 in a pear tree.
Reply #20
July 02, 2010, 10:04:21 am
tkisling
My Bunneh
Reply #20 on:
July 02, 2010, 10:04:21 am »
I got the car running so now i just need to put the sending unit in an the back seat needs to be installed. In my haste to install the fuel sending unit I lost the o ring inside the tank. Hopefully i can find a new one that fits.
Reply #21
July 02, 2010, 10:47:39 am
Baron VonZeppelin
Reply #21 on:
July 02, 2010, 10:47:39 am »
If you can't source one locally,
I think autohausaz.com sells them.
They have them for my rabbitruck.
Their listing will sometimes give the dimensions of an o-ring, which might help you to source one locally.
Don't fill it much more than 1/3 - fuel is probly going to slosh enough to spill/seep out of the top until you get an o-ring.
Reply #22
July 02, 2010, 07:58:56 pm
tkisling
My Bunneh
Reply #22 on:
July 02, 2010, 07:58:56 pm »
I bought an o ring at NAPA that pretty much fit. I installed it with the sender so hopefully everything fits and works.
Pages:
General Information
Troubleshooting
