Author Topic: FS: resurfaced june 29th 200mm flywheel British Columbia $75 CAD  (Read 3589 times)
June 29, 2010, 09:17:22 pm
  • 3468
    • McScrubbins Body Wash
Reason for selling is I have a 210mm PP and clutch disk and didn't realize my FW was 200mm not 210 as I had originally believed it to be based on my transmission & year.
I'm asking $75 which is $1.50 less than amount I paid to have it resurfaced. I have the invoice taped to the flywheel and it would of course be included incase there are any issues with the flywheel.
It's perfectly clean and painted,except for the machined surfaces obviously, so someone please come take it and use it!
I will be oiling the machined surface to prevent oxidation.
the only defect with the flywheel is it is missing a tooth but the machinist said that didn't matter...
I never noticed an issue with the missing tooth on starts.
« Last Edit: July 06, 2010, 09:39:50 pm by Smokey Eddy »
