Author Topic: fml... anyone have a 210 flywheel?  (Read 4966 times)
Reply #15June 30, 2010, 11:26:40 am
Re: fml... anyone have a 210 flywheel?
« Reply #15 on: June 30, 2010, 11:26:40 am »
the only difference is the mk3 trans. it has the bigger 24 spline input shaft. all mk1 and mk2 020 trannys had the same 22mm input shaft.
Reply #16June 30, 2010, 11:54:41 am
« Reply #16 on: June 30, 2010, 11:54:41 am »
I think 16v use the larger spline.
Reply #17June 30, 2010, 12:58:00 pm
  • 3468
    • McScrubbins Body Wash
« Reply #17 on: June 30, 2010, 12:58:00 pm »
ok so you're telling me that Catlin's mk3 flywheel will work with my 210mm clutch and pressure plate and has no relevancy to the 22mm input shaft on my MK2 transmission! :D
Huzzah!
I just need to find a buyer for my flywheel now...
dang. Anyone hear of anything ever please please please let me know.
Reply #18June 30, 2010, 12:59:03 pm
  • 3468
« Reply #18 on: June 30, 2010, 12:59:03 pm »
Is it okay to clean out the bellhousing with solvent?
I want to make sure no oil/grease gets anywhere near my clutch disk.
Reply #19June 30, 2010, 01:38:51 pm
RadoTD
  • 513
    Stage WTF
« Reply #19 on: June 30, 2010, 01:38:51 pm »
Huzzah!
yeah, that PP/flywheel should work. It's just the clutch disc that's on the input shaft
and the best place to sell parts is on dubberz.com, make an account there
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #20June 30, 2010, 02:33:55 pm
  • 3468
« Reply #20 on: June 30, 2010, 02:33:55 pm »
Thanks Matt, will do.
Reply #21July 01, 2010, 10:09:31 am
« Reply #21 on: July 01, 2010, 10:09:31 am »
a FW is a FW. the clutch and the trans input shaft are what make the mk3 special. clutch is still 210mm. just has a bigger hole in the middle for the 24 spline input shaft. instead of the 22 spline shaft of our standard 020 trannies. yes ed, his FW will work. just dont use the mk3 clutch.
use:
mk2 PP
mk2 disk
mk3 FW
mk2 trans.
it will work wonderfully.
Reply #22July 01, 2010, 04:29:48 pm
« Reply #22 on: July 01, 2010, 04:29:48 pm »
It is fine to clean it with solvent. Maybe stay away from the pushrod area, but they have seals that hold up to oil so it should be fine. I used brake cleaner on mine, after Brokevw put it into the ultra sonic cleaner and I got it a little dirty.
Reply #23July 01, 2010, 05:00:56 pm
« Reply #23 on: July 01, 2010, 05:00:56 pm »
yes, 16v trannies are bigger also. (input shaft)
Reply #24July 02, 2010, 08:50:08 pm
RadoTD
  • 513
    Stage WTF
« Reply #24 on: July 02, 2010, 08:50:08 pm »
Or buy the 6sp 02M off of dubberz  ;)
Reply #25July 02, 2010, 10:12:03 pm
  • 3468
« Reply #25 on: July 02, 2010, 10:12:03 pm »
link?
Reply #26July 02, 2010, 10:13:38 pm
  • 3468
« Reply #26 on: July 02, 2010, 10:13:38 pm »
Catlin has one he will send me for shipping (around $40)
I really hope i can sell mine and at least get something back for it :(
