Author Topic: wanted: an clutch alignment tool for 1.6 TD  (Read 3631 times)
June 28, 2010, 06:13:19 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« on: June 28, 2010, 06:13:19 am »
Does anyone have an clutch alignment tool for a 1.6 TD?
Thanks
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #1June 28, 2010, 06:53:21 am
Re: wanted: an clutch alignment tool for 1.6 TD
« Reply #1 on: June 28, 2010, 06:53:21 am »
I don't, but I put a screwdriver in between the flywheel and clutch disc all the way around. My little bladed flat screwdriver had the perfect spacing, then I tightened the PP bolts. When I put the trans onto the engine I wiggled it and it fell on in less than 5 seconds.
Might try that if someone doesn't have one for you.
Reply #2June 28, 2010, 07:07:17 am
« Reply #2 on: June 28, 2010, 07:07:17 am »
I just eye it up and put it as close as possible. In my opinion it isn't critical to get it exactly centered. The input shaft will force the clutch to where it needs to go although sometimes you will need to rotate the shaft by via the CV flanges to get it to slide in.
Reply #3June 28, 2010, 09:25:04 am
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: June 28, 2010, 09:25:04 am »
I have one but I still have yet to use it.
Reply #4June 28, 2010, 10:51:48 am
« Reply #4 on: June 28, 2010, 10:51:48 am »
any clutch alignment tool for our style of clutch will work, except aba/aaz alignment tools. they have the bigger input shaft.
any gasser tool will work.. plastic disk with a peg sticking out of the middle, just make one or improvise. ive eyeballed more vw clutches than ive used the tool on. like tyler said, it doesnt have to be perfect.
