Author Topic: Temp Switch Problem  (Read 3487 times)
June 23, 2010, 11:24:18 am
ein bora
  • 377
Temp Switch Problem
« on: June 23, 2010, 11:24:18 am »
On my 92 eurovan when I got it had problems with the gauge cluster - namely the rpm the temp and gas gauge. Solved the rpm and gas problem and determined that the temp problem is in the 4 - wire sending unit, as I used a spare that I had and now it works better but not accurately. With the two speed fan running full tilt coming off the highway, and it's been hot and humid - it's only reading about a quarter way up on the gauge. The replacement switch has a different color and part number and has 140 degrees marked on it. The original has 120 degrees marked on it. Doing some research I find that there are a number of different temp switches available with all different part numbers and colors.
Anybody know if the gauge accuracy is determined by the switch??
Thanks.
If you can't take advice - then you can't be helped!
Reply #1June 28, 2010, 05:42:08 am
  • 1739
Re: Temp Switch Problem
« Reply #1 on: June 28, 2010, 05:42:08 am »
I'm pretty sure the square shaped connector switches have different color codes for a reason, different engines etc
