Author Topic: 82 vanagon wiper switch  (Read 8984 times)
June 16, 2010, 06:52:17 pm
motomike33y
  • 190
« on: June 16, 2010, 06:52:17 pm »
wiper switch quit on my vanagon. took it off and don't see any obvious problems.  wiper motor works when I jump it.  Have a couple other switches from jetta and rabbit of same vintage.  numbers different but look identical to vanagon--however they don't work either-no obvious reasons.  New switch for vanagon about triple that for rabbit.  Why?  Anything I can do to try rehabbing switch?  all three switches have same basic #321953503, but different suffixes.  vanagon "A", other 2 are B and C.  Suggestions, tips?  thanks.
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress           suzuki samurai hardtop that may someday be diesel
2012 golf tdi
Reply #1June 16, 2010, 08:53:39 pm
  • 1739
Re: 82 vanagon wiper switch
« Reply #1 on: June 16, 2010, 08:53:39 pm »
try a new wiper relay
Reply #2June 17, 2010, 05:14:29 am
motomike33y
  • 190
« Reply #2 on: June 17, 2010, 05:14:29 am »
Where would that be at?  I don't have my Bentley's here to check.  thanks
2012 golf tdi
Reply #3June 17, 2010, 05:28:39 am
  • 1739
« Reply #3 on: June 17, 2010, 05:28:39 am »
For an 82, it shows that it's the one on the r/s of the relay panel, position 5
Reply #4June 18, 2010, 05:20:40 am
motomike33y
  • 190
« Reply #4 on: June 18, 2010, 05:20:40 am »
found it, and in Bentleys it's shown as only being needed for intermittent switch wiper.  I located several other relays in my piles of electrical goodies.  There must be a way to test the relay to see if its any good.  Also if its only needed for the intermittent phase, the wipers would work on regular high or low without the relay wouldn't they?   thanks.
2012 golf tdi
Reply #5June 18, 2010, 07:35:27 am
  • 1739
« Reply #5 on: June 18, 2010, 07:35:27 am »
 Try it anyways. Until the mid 90's ,wiper circuits were the most complicated wiring in VW's
Reply #6June 23, 2010, 07:24:38 am
motomike33y
  • 190
« Reply #6 on: June 23, 2010, 07:24:38 am »
tried all of my collection of used relays, none of them made any of my collection of used wiper switches work-guess next step is to try parts place.
2012 golf tdi
Reply #7June 23, 2010, 03:56:45 pm
  • 1739
« Reply #7 on: June 23, 2010, 03:56:45 pm »
I'm sure i have a god used one if you want, just postage and a buck or 2 would cover it. let me know.
Reply #8June 24, 2010, 05:54:09 am
motomike33y
  • 190
« Reply #8 on: June 24, 2010, 05:54:09 am »
I can jump from the hot wire to other connectors to get the wiper and washer to work, so the motor is ok.  I checked the fuses and they all appear ok-altho they are the old old style so I may replace them just on general principle.  I think I'm going to try to take apart one of the switches because they appear to be a simple matter of sliding contacts.  I can't see visually any difference between the 3 switches I have that have the same number but different suffixes.
2012 golf tdi
Reply #9June 24, 2010, 10:28:03 am
motomike33y
  • 190
« Reply #9 on: June 24, 2010, 10:28:03 am »
yes, using the connections that would ordinarily be hooked to the wiper switch.
2012 golf tdi
Reply #10June 25, 2010, 05:17:23 am
motomike33y
  • 190
« Reply #10 on: June 25, 2010, 05:17:23 am »
yep, and while I was fiddling and trying relays, I must have flummoxed something because now the starter won't work--again.  good thing I wasn't planning on having to use the vehicle immediately.
2012 golf tdi
Reply #11June 26, 2010, 08:26:09 pm
  • 1739
« Reply #11 on: June 26, 2010, 08:26:09 pm »
Maybe the X [75] relay is gone. Does the heater fan work?
Reply #12June 28, 2010, 05:09:48 am
motomike33y
  • 190
« Reply #12 on: June 28, 2010, 05:09:48 am »
I don't think it does, altho that also has been inconsistent.  Something else I should check out?  How does the heater fan tie into the starter and/or windshield wiper switch?
2012 golf tdi
Reply #13June 28, 2010, 05:39:55 am
  • 1739
« Reply #13 on: June 28, 2010, 05:39:55 am »
The starter issue does confuse things, but maybe it's just the starter. The x relay powers all the functions that pull current when starting-i.e.- interior fan, wipers some lights etc. It's important to check that when the wipers don't work whether the fan etc is/isn't working
Reply #14June 28, 2010, 10:04:12 am
motomike33y
  • 190
« Reply #14 on: June 28, 2010, 10:04:12 am »
I'll have to check that relay out when I get a chance.  I think maybe some other factor for starter-perhaps I moved wires when fiddling with the relay and fuse box for the wiper switch.  When I get a chance, I'll check things more thoroughly.
2012 golf tdi
