Author Topic: Hot Tanking  (Read 7102 times)
June 14, 2010, 11:49:11 am
  • 3468
    • McScrubbins Body Wash
Hot Tanking
« on: June 14, 2010, 11:49:11 am »
I don't know anything about hot tanking a block.
I have a bare aaz that i'd like to really clean up. It came from the east coast of canada so it's got some hefty surface rust.
Is there anything i have to be aware of? like ... hot tanking will then require every surface to be re-machined?
I have a very small solvent tank for cleaning parts - definately not suitable for a block but i guess i could find a derelict spot somewhere and just unload a few cans of brake cleaner on it?
I want to make this block look re surfaced and paint it black.
I can post pics if needed.
Hot tanking like this...
« Last Edit: June 14, 2010, 11:53:14 am by Smokey Eddy »
Reply #1June 14, 2010, 01:09:01 pm
  • 3468
Re: Hot Tanking
« Reply #1 on: June 14, 2010, 01:09:01 pm »
Would i be better off to pressure wash it in the sun and then dry it really well?
I really don't want to have to hand sand it. blech.
I attacked it with a wire brush yesterday but it still would have taken ages.
Thanks for reading.
Reply #2June 14, 2010, 02:57:16 pm
  • 1739
Re: Hot Tanking
« Reply #2 on: June 14, 2010, 02:57:16 pm »
Do you have a food whole sale shop near you? Buy a couple buckets [20l] of malt vinegar. Then a big plastic tub big enough for the block. Soak it in the vinegar for a couple of days, remove and wire brush it. Then repeat. You should be able to get it clean enough to rinse  well and paint.
Reply #3June 14, 2010, 03:13:00 pm
Baron VonZeppelin
Re: Hot Tanking
« Reply #3 on: June 14, 2010, 03:13:00 pm »
Vinegar works good, any kind of vinegar.
The type i buy in gallon jugs at grocery store is only 5%.
Works great on stuff. Never done anything with it the size of a block though.
Best thing would be to have it furnace cleaned since rust is main issue. A lot of automotive machine shops have that now. And its way better than hot tanking.
if you have any rusty brackets etc... have them done too.
The old school hot tanks aim more for degreasing.
Its hit and miss on rust.
Either way you go, no re-machining is necessary.
But all the bearings will need to be removed prior, and of course any plugs.
Reply #4June 14, 2010, 05:04:30 pm
  • 3468
Re: Hot Tanking
« Reply #4 on: June 14, 2010, 05:04:30 pm »
okay. My main concern was the bearing surfaces (not the bearings them selves but where they sit) and the bores, gasket mating surfaces and what have you. I'll try the vinegar since i have a big blue tote that will fit the bare block.
Thanks guys! It should be soaking by the time i go to bed tonight :)
Reply #5June 15, 2010, 12:30:05 am
  • 3468
Re: Hot Tanking
« Reply #5 on: June 15, 2010, 12:30:05 am »
its soaking on one side right now :)
4 gallons of vinegar later. we'll see how it looks tomorrow.
I also got a gal of Varsol.
Reply #6June 15, 2010, 03:57:01 am
rs899
  • 647
Re: Hot Tanking
« Reply #6 on: June 15, 2010, 03:57:01 am »
Why vinegar?  Why not something that's made to handle rust like phosphoric acid?  I buy the stuff at the big box home stores for around $15/gallon.  Either way, you will need to degrease well before you use an acid or it won't work very well, I would think.
Reply #7June 15, 2010, 05:33:49 am
Re: Hot Tanking
« Reply #7 on: June 15, 2010, 05:33:49 am »
http://www.fullsizebronco.com/forum/showthread.php?t=175550
I don't know about this, but have always wanted to try. Seems all you need is steel that is not stainless, pool ph balancer, and a battery charger. Might work for you.
They also said even with regular steel don't do it under a roof as there are fumes. 2 amp to 10 amp was the settings IIRC :D
Reply #8June 15, 2010, 08:16:50 am
  • 3468
Re: Hot Tanking
« Reply #8 on: June 15, 2010, 08:16:50 am »
the vinegar was $2.50 CAD gallon at walmart :P we'll see how well it worked.
I'm not concerned about the grease. it's not that greasy and i have varsol to take care of that.
I really appreciate the info but after reading it i think that's more work that just grabbing some emery cloth or a wire wheel on a drill and going to town on the block which i will likely do afterwards anyways.
Reply #9June 15, 2010, 09:43:33 am
Re: Hot Tanking
« Reply #9 on: June 15, 2010, 09:43:33 am »
I hope you are taking before and after pics
Reply #10June 15, 2010, 10:27:48 am
rs899
  • 647
Re: Hot Tanking
« Reply #10 on: June 15, 2010, 10:27:48 am »
Oh, I see now that you are soaking it in vinegar.  Yeah, too expensive to do that with phosphoric acid, but it works so well that you normally just spray it on and wire brush a few times.  Shouldn't take more than a pint or quart, maybe.  See if the vinegar works.  You can also try muriatic acid (carefully) but have to figure out a way to neutralize it....and don't spray that stuff if you want to keep your lungs...
Reply #11June 15, 2010, 02:57:05 pm
  • 1739
Re: Hot Tanking
« Reply #11 on: June 15, 2010, 02:57:05 pm »
That is one reason i mentioned using vinegar. It's not toxic , and will do a lot of the work without you having to anything other than watch the tube and drink beers while it's at it. Using a wire brush wheel can be almost as toxic as acid if you don't use a good mask, messy also.
Reply #12June 15, 2010, 10:01:58 pm
Baron VonZeppelin
Re: Hot Tanking
« Reply #12 on: June 15, 2010, 10:01:58 pm »
Yep, the vinegar should do 90-100% of the job.
The varsol degreasing probly should have been done first.
I don't neutralize anything after the vinegar.
It leaves a treated looking finish on metal that temporarily resists rusting. Seems to be no need. I go strait to paint after its dried off.
If you rinse/neutral with water = it will orange residue rust when its dried. Especially in pits and crevices.
maybe just run an oily rag through the cylinders when its dry.
I also prefer to paint engines with a brush and oil base paint.
Versus aerosal. A quart will do 2 coats on about 6-8 shortblocks with oilpans. No overspray, better film build, seems to hold up better for longer.
Reply #13June 15, 2010, 10:05:34 pm
Baron VonZeppelin
Re: Hot Tanking
« Reply #13 on: June 15, 2010, 10:05:34 pm »
Get a pic of the half that soaked - versus the half that hasn't soaked yet. I'm with Burn, pix would be interesting.
Reply #14June 16, 2010, 03:50:40 am
rs899
  • 647
Re: Hot Tanking
« Reply #14 on: June 16, 2010, 03:50:40 am »
I wouldn't consider phosphoric acid particularly toxic.  It's in Coke...
