Author Topic: Vacuum pump seized, got lucky  (Read 1917 times)
June 14, 2010, 05:28:44 am
Vanagoner
  • 219
« on: June 14, 2010, 05:28:44 am »
The night before this happened, I lost power assist on my brakes driving home in the neighborhood.  I've been chasing an oil leak, so I used the vac. loss as an excuse to pull it out, look at it and replace the o-ring at the base of the vac. pump.  I ran it for a few minutes after replacing the o-ring and called it a day.  The next morning, I started it to drive off, and the vac assist was back.  "ok, I guess it fixed itself" (it was a rotary vane pump, I didn't suspect trouble).  I drove down the block and suddenly a shrieking started, and the oil light turned on about 3 seconds after the noise.  I had it shut down within 3 seconds after the light.  I could smell a little burning rubber after I stopped.
  Sure enough, the back of the timing belt had the impression of the freshly polished IM shaft pulley in the rubber, but the shaft didn't break!  I am careful not to over-tighten the belt, I use the "45 degree twist" rule.
I swapped out the seized vacuum pump for a spare rotary vane pump I had on my core engine, and all is well.  I had Schaffer's molybdenum EP additive in the engine, which may have helped.  It still runs great, no new or ominous noises, so I think I'm ok.  Still trying to find the leak, (think it might be a galley plug) but I'm thankful that I dodged the bullet on what could have easily been a catastrophic failure.  Thought you guys would be interested to know.
Sage
