Author Topic: Cold start choke is stuck...  (Read 2218 times)
June 13, 2010, 10:49:18 am
brandon5
  • 88
« on: June 13, 2010, 10:49:18 am »
So i pulled the choke the other day because it was a cold morning and it stuck wide open.... How do i fix this? It wont push back in for anything.
Engine is a 1.9td thanks.
Reply #1June 13, 2010, 11:02:09 am
Re: Cold start choke is stuck...
« Reply #1 on: June 13, 2010, 11:02:09 am »
If we want to get technical it's not a choke but a cold start timing advance.
Anyways, it's hooked up to the back of the pump. Use a screwdriver to push it back to where it should be. You'll need a long one.
Reply #2June 13, 2010, 04:25:06 pm
brandon5
  • 88
« Reply #2 on: June 13, 2010, 04:25:06 pm »
Thanks man.
And instead of making a new thread ill post here.
My rpms sit at like 1000 - 1100 when im idling.
Does that mean i need to do the timing?
Reply #3June 13, 2010, 05:26:08 pm
Mark(The Miser)UK
  • 1557
« Reply #3 on: June 13, 2010, 05:26:08 pm »
Thanks man.
Nope, it just means you need to back off the stop screw. ::)...
...However, if that means that it idles rough, then timing may be out a little,
or maybe injectors a little imbalanced :)
Mark-The-Miser-UK
Reply #4June 13, 2010, 08:17:45 pm
« Reply #4 on: June 13, 2010, 08:17:45 pm »
Reply #5June 14, 2010, 11:04:21 am
brandon5
  • 88
« Reply #5 on: June 14, 2010, 11:04:21 am »
Thanks alot guys. My car runs because of this site.
Reply #6June 15, 2010, 09:47:01 am
« Reply #6 on: June 15, 2010, 09:47:01 am »
Mission accomplished  :)
