Author Topic: which turbo is best?  (Read 6913 times)
June 13, 2010, 12:23:48 am
gribur
  • 84
« on: June 13, 2010, 12:23:48 am »
I have a MK3 Golf TD and was wondering which turbo is the best for this car? i want it to be quick off the line , not worried about top end too much, i am looking for fast 0-60.
here is what i have on hand,
A)  KKK K03
B)  KKK K14
C)IHI turbo
   Turbo Spec-VJ11 9101
   Serial Number RHB5 25076 A
   Parts Number-F220 B
   and stamped in a different spot is
   R3
   6A
   52E
   12-R
   3
   effective limit of this turbocharger is about 140kW. or approx 180hp
D) IHI Turbo
    Turbo Spec-VF 28603
    Serial Number-RHB5 17125 A
    Parts Number 14412AA002
    3
    K
    0K
    52K
    20R5
    VF28
    comes on boost around 3100rpm, Expect to max out the VF23 somewhere in 250KW range, 300-350 hp
I don't know turbos, i just want to put one on and have it perform the best.  if anyone can do turbo research and let me know, like i said i dont know much so i am asking for help with this one. Please let me know what you would pick and why.
cheers
Reply #1June 13, 2010, 06:07:33 am
gribur
  • 84
Re: which turbo is best?
« Reply #1 on: June 13, 2010, 06:07:33 am »
i can try to find more info on the ihi if needed
Reply #2June 13, 2010, 08:35:47 am
« Reply #2 on: June 13, 2010, 08:35:47 am »
from what others have said on here I would say that the K14 would be the way to go...assuming it is for a 1.6?
Reply #3June 13, 2010, 10:59:55 am
« Reply #3 on: June 13, 2010, 10:59:55 am »
How many PSIs are you aiming for?
Reply #4June 13, 2010, 03:32:01 pm
gribur
  • 84
« Reply #4 on: June 13, 2010, 03:32:01 pm »
forgot to put that it is an AAZ 1.9l, i am not sure how mant psi 18-20 maybe
Reply #5June 13, 2010, 05:15:35 pm
GEE-BEE
  • 1604
« Reply #5 on: June 13, 2010, 05:15:35 pm »
Ko3 Hybrid is best
I have ceramic coated housings
Ko4 Hot section  Ko3 cold side
17 psi, 1425 temp
at 75 mph ,7 psi and 675 temp
2.5 s/s Downpipe and exhaust
Gb
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #6June 13, 2010, 05:25:00 pm
gribur
  • 84
« Reply #6 on: June 13, 2010, 05:25:00 pm »
like i said i dont know much about turbos, i dont even know what i would need if i went with an IHI. i just want it to be able to spin tires off the line and get to 60 pretty quick.
Reply #7June 13, 2010, 05:31:59 pm
gribur
  • 84
pics of stuff
« Reply #7 on: June 13, 2010, 05:31:59 pm »
heres some pics of a few turbo bits i have. let me know what you guys think, not sure of inter cooler will even work on the golf.
« Last Edit: June 13, 2010, 05:36:03 pm by gribur »
Reply #8June 13, 2010, 09:23:48 pm
macka
  • 957
« Reply #8 on: June 13, 2010, 09:23:48 pm »
the vj11 is outt of a suby I am guessing? Its not really a diesel set up, more for 1.8 gasser. I'd look for a better fit for the 1.9 like a K24.
Quote from: Vincent Walden
Reply #9June 13, 2010, 09:32:12 pm
gribur
  • 84
« Reply #9 on: June 13, 2010, 09:32:12 pm »
what is the difference between a gasser turbo and a diesel one?  should i just sell the two IHI's
Reply #10June 13, 2010, 09:59:53 pm
mystery3
  • 774
« Reply #10 on: June 13, 2010, 09:59:53 pm »
What did that IC come out of?
Reply #11June 13, 2010, 10:05:33 pm
gribur
  • 84
« Reply #11 on: June 13, 2010, 10:05:33 pm »
i think it was out of a mazda ? i bought all the parts from a guy who was going to turbo a 318i. am pretty sure he said mazda, maybe 626?
Reply #12June 14, 2010, 03:38:27 am
macka
  • 957
« Reply #12 on: June 14, 2010, 03:38:27 am »
the vj11 is just not a great turbo. The vj26 is used on the isuzu 4x4 diesel engine and gassers use them to hit the 350 hp range. They are watercooled turbos which has its good points and bad points.
