Author Topic: 18 psi BOOST  (Read 5454 times)
June 11, 2010, 01:58:32 pm
rodpaslow
  • 670
18 psi BOOST
« on: June 11, 2010, 01:58:32 pm »
I've been reading, a bit of time at work today on the TDI website.  I'm a bit concerned as they suggest that cylinder pressure is too great if you boost more that 18 psi at sea level.  They have several warnings about this for a TDI.  I will have a intercooler (water to air) before my car is running.  Is this an issue for IDI cars as well, or because of the precombustion chamber we can handle more boost?
Reply #1June 11, 2010, 02:06:01 pm
smoken u
  • 231
Re: 18 psi BOOST
« Reply #1 on: June 11, 2010, 02:06:01 pm »
im no expert on this but 18 psi seems low to be concerned about cylinder pressure in a TDI. TDI's have lower compression than IDI's so should be able to handle more boost than an IDI which has insane compression, as long as your intercooled i cant see why you couldnt run a bit over 20 psi on a TDI with possibly an upgraded turbo seeing as those little vnt17's cant handle much lol.
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #2June 11, 2010, 02:24:42 pm
GEE-BEE
  • 1604
Re: 18 psi BOOST
« Reply #2 on: June 11, 2010, 02:24:42 pm »
Iam running 17 psi, 1325 temp on Egt....
No problem's
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3June 11, 2010, 02:51:38 pm
Re: 18 psi BOOST
« Reply #3 on: June 11, 2010, 02:51:38 pm »
maybe on a stock tdi
Reply #4June 12, 2010, 05:27:23 am
carrizog60
  • 978
Re: 18 psi BOOST
« Reply #4 on: June 12, 2010, 05:27:23 am »
used to run above 30psi max boost and the engine was ok...
Portugal
Reply #5June 13, 2010, 08:39:33 am
OM617
Re: 18 psi BOOST
« Reply #5 on: June 13, 2010, 08:39:33 am »
18psi is too much for the turbo. The engine can easily handle more pressure.
Above that it will be spinning too fast, the same concept as running your engine at 6000rpm.
Reply #6June 13, 2010, 09:20:01 am
Re: 18 psi BOOST
« Reply #6 on: June 13, 2010, 09:20:01 am »
what turbo is on your engine? i used to run 30+ out of my VNT..
Reply #7June 13, 2010, 09:26:52 am
OM617
Re: 18 psi BOOST
« Reply #7 on: June 13, 2010, 09:26:52 am »
I doubt it was the factory VNT15.
Reply #8June 13, 2010, 09:52:21 am
Re: 18 psi BOOST
« Reply #8 on: June 13, 2010, 09:52:21 am »
it most definitely was not a stock VNT 15.. it was a VNT17.. and yea, it made 30 psi just fine. really starts screaming about 25 psi..
Reply #9June 13, 2010, 10:13:43 am
OM617
Re: 18 psi BOOST
« Reply #9 on: June 13, 2010, 10:13:43 am »
They usually do when oversped.
Reply #10June 13, 2010, 10:24:57 am
dts67
  • 68
Re: 18 psi BOOST
« Reply #10 on: June 13, 2010, 10:24:57 am »
Read that too but lets be under no illusion, any tuning is going to increase the pcps but most seem to get away with it.
Reply #11June 13, 2010, 10:27:14 am
Re: 18 psi BOOST
« Reply #11 on: June 13, 2010, 10:27:14 am »
it was oversped because of extremely retarded timing.. it doesnt scream or make 30+ psi anymore..
Reply #12June 14, 2010, 08:55:35 am
rodpaslow
  • 670
Re: 18 psi BOOST
« Reply #12 on: June 14, 2010, 08:55:35 am »
I don't have a TDI, but I was reading the faq in the form that said 18 psi max.  Mine is a 1.6 TD with a air to water intercooler with a T3 turbo (supposed to be a 92 engine) that has been fully rebuilt engine with arp fasteners for the important bits, metal hd gasket, etc.  I was wondering for longevity if 18 psi was the max.  It sounds like from the replies it can handle much more.  If the T3 will do it, I'd like to run about 25 most of the time - no special reason.
Reply #13June 15, 2010, 10:09:24 am
Re: 18 psi BOOST
« Reply #13 on: June 15, 2010, 10:09:24 am »
25 most of the time will mean you are pumping in a significant amount of fuel, your EGT's will go up and your wallet size go down..
too much fuel and heat is deathly to these engines and is what causes damage, not boost. However boost is relevant to amount of heat, which is relevant to amount of fuel.. 20psi is wayy more than enough to have loads of fun while maintaining longevity.
