Author Topic: Performance TDI Cams 260/260 11mm Lift Race Spec!  (Read 8727 times)
June 08, 2010, 02:00:44 pm
shortysclimbin
  • 138
    • Performance Diesel Engineering
« on: June 08, 2010, 02:00:44 pm »
 I am able to offer up a great offer to kick off the best camshaft ever designed for the VW VE TDI. After two years of working with an OEM casting facility I am having a limit run of TDIMEISTER 260/260 11mm lift cams made up. To commemorate the offering of this camshaft I will be offering a LIMITED group buy rate of $338.41 plus shipping, a substantial discount, for the first 10-25 camshafts purchased between now and June 15th. To qualify for this rate I need a minimal of 10 purchases, and will cap the group buy at 25 cams total, after that all cams will be offered at the Retail price of $383.00 USD a piece. During this time period I will also be offering my $225.00 Race cam clearancing services at a low $202.50 plus shipping rate. And anyone who also needs stiffer valve springs or performance hydraulic lifters to compliment the set I am offering these to group buy customers with a 10% discount!
Please note all cams will fit with our clearancing service and should offer up to 5WHP more than the regrind or billet cams currently on the market. That means nets up to a 20WHP gain with proper tuning changes! On top of this most users have found drops of around 100 degrees in EGT temps and a 1 point lower dynamic Compression ratio! This means more room for boost, power, And torque with no worry of starting issues!
Reply #1August 03, 2010, 12:30:23 pm
greentdi
  • 32
Re: Performance TDI Cams 260/260 11mm Lift Race Spec!
« Reply #1 on: August 03, 2010, 12:30:23 pm »
I am in need of a cam for my build. Is this cam plug and play or do I have to machine pistons for valve clearance. I was going to get another colt cam but I will go this route if you have one available.
Reply #2August 18, 2010, 06:42:58 pm
shortysclimbin
  • 138
« Reply #2 on: August 18, 2010, 06:42:58 pm »
Green
You will need to machine your head a little to clear the cam itself.  (The lifter pockets are not big enough on most heads).  I offer a service to do this with your head if you dont have a way to cut them down yourself. If you have anymore questions you can reach me at [email protected]
