Author Topic: swapping LDA of a vanagon pump  (Read 2909 times)
June 08, 2010, 10:07:22 am
arnold
« on: June 08, 2010, 10:07:22 am »
Hello
I have a NEVER used vw t3/vanagon td pump sitting in front of me,it even came out a sealed bosch box !
My brother found it at school and they let him have it,yes i am very happy now cuz my pump needed a rebuild...
Now this pump has the weird LDA with the lever ans boost can system,i took it of and looked inside the pump,all nice and shiny.
pump nr is VE4/9F2250R170
Can i just swap the LDA with the one of a regular td pump,mount and run it ?anyone ever done this   ?
cheers
Reply #1June 08, 2010, 10:26:38 am
arnold
Re: swapping LDA of a vanagon pump
« Reply #1 on: June 08, 2010, 10:26:38 am »
i found a pic of the new pump's lda
http://www.brick-yard.co.uk/uploads/jx-pump01.jpg
Reply #2June 08, 2010, 01:52:25 pm
arnold
« Reply #2 on: June 08, 2010, 01:52:25 pm »
The vanagon's governor spring assembly and dynamic advance curve will be different, but I believe either LDA version will bolt right on without issue.
You are right,it just bolted on !!!
I had to swap the governor assembly because the vanagon's shaft is longer,so i need to swap the spring and washers of the dynamic advance piston also, ?
The golf pump has 3 washers and the vanagon's only 2,i haven't compared the spring yet
the governor : you cant really see the lenght of the shaft,i had to swap it anyway since mine is a bit better  :)
The new monster  ;D
« Last Edit: June 08, 2010, 02:24:21 pm by arnold »
Reply #3June 08, 2010, 03:11:27 pm
arnold
« Reply #3 on: June 08, 2010, 03:11:27 pm »
Will do  ;D
in fact i will try the vanagon's spring,the golf's AND i have a green spring and washers from a NA pump so that i can give a good comparisation
