Author Topic: 95-97 Passat suspension Q  (Read 2924 times)
June 08, 2010, 07:30:00 am
farkman
  • 172
« on: June 08, 2010, 07:30:00 am »
Hi guys,
Does anyone know if 95-97 Passat suspension would fit in a MK3 Golf. The Golf will not be going on the road mind you, it's simply
to swap out the good suspension with some junk and then send it to the scrap yard.
Will it physically fit and the bolt holes match up?
Thanks
Reply #1June 19, 2010, 12:58:28 pm
Re: 95-97 Passat suspension Q
« Reply #1 on: June 19, 2010, 12:58:28 pm »
I don't know for sure but I just checked with a supplier and they say the struts are the same 92-97 front and rear. I don't know what year the B3 ended but B3 suspension definitely works on a mk3. You may need to change strut mounts but if it's just going to the yard the weight should hold it.
