Author Topic: cooling system pressure and expansion tank cap  (Read 3324 times)
June 07, 2010, 06:21:04 pm
overdrivegear
  • 120
« on: June 07, 2010, 06:21:04 pm »
It was recently brought to my attention that I should not use a black expansion tank with my diesel.  I did a 1.6 NA swap into a cabriolet (videos here):
1987 VW Cabriolet 1.6 Diesel engine running pt. 1
1987 VW Cabriolet 1.6 diesel running pt. 2
and I just kept the gasser expansion tank and cap.  Someone told me that if I keep that black cap, I will run the risk of blowing a head gasket ???
So my questions are, does the color of the expansion cap make a difference and if so what cap should I use?  Do these coolant caps actually vent pressure according to their color?  I was under the impression that these caps didn't vent pressure at all.
1985 Westy Golf 1.6 NA
1987 Cabriolet (soon to be 1.6 NA)
Reply #1June 07, 2010, 07:29:11 pm
GEE-BEE
  • 1604
Re: cooling system pressure and expansion tank cap
« Reply #1 on: June 07, 2010, 07:29:11 pm »
I installed the later round type tank....
 non sensor
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2June 07, 2010, 07:36:45 pm
  • 1739
« Reply #2 on: June 07, 2010, 07:36:45 pm »
The caps will vent , although only at higher pressures than normal-i.e. when you're overheating, so no, not in a normal fashion. In that case, i don't  see why a different cap pressure would make a difference, but i would try to find a definite answer if you're having issues.
Reply #3June 07, 2010, 07:45:31 pm
overdrivegear
  • 120
« Reply #3 on: June 07, 2010, 07:45:31 pm »
I'm not having issues.  I just wanted to avoid a noob mistake with the wrong 'cap pressure'.  Kinda sounds silly, but then again there is a fair amount of silly business with these Volkswagens and I wouldn't put it past them.
Reply #4June 07, 2010, 09:20:55 pm
Baron VonZeppelin
« Reply #4 on: June 07, 2010, 09:20:55 pm »
I'm gonna say .... ol wives tale.  ;)
[but reserve the right to be wrong]
Maybe should send this in to MythBusters.
I believe they will vent in the high teens-20'ish, but never seen black or blue listed as gas or diesel specific - or even listed with a psi rating. So figured they were the same other than color of the plastic.
I have both color caps amongst my a1/a2 diesels.
I think the score is 3 black and 2 blue, on my fleet.
Reply #5June 07, 2010, 10:39:48 pm
one_tinted_tail
  • 22
    • http://www.CMLUA.com & www.hourofthetime.com
« Reply #5 on: June 07, 2010, 10:39:48 pm »
sounds like bumper fluid talk as well, and I like the reservation of right to be wrong, HA!
they pop at extremes, yes, but not aware of color/pressure differences.
My mother named me Brian;
Ive owned many VAG cars but currently have it narrowed down to my 'UrSula' a '95 Audi S6 (dahlback RS2'd & then some) and 'Henryetta' an '85 Jetta TD whose peppy on the veg and is as pretty as her name.
