water pump to block, square 0-ring?
Topic: water pump to block, square 0-ring? (Read 2237 times)
June 07, 2010, 04:21:12 pm
79rabbit4dr
June 07, 2010, 04:21:12 pm »
I seem to remember them being square cut o-rings but the parts place is telling me they call for round cut o-ring's...? Anyone got a solid answer???
June 07, 2010, 04:59:15 pm
Re: water pump to block, square 0-ring?
June 07, 2010, 04:59:15 pm »
IIRC They're round-cut, and exactly the same size as the t-stat o-ring.
June 07, 2010, 06:20:18 pm
79rabbit4dr
June 07, 2010, 06:20:18 pm »
Quote from: Vincent Waldon on June 07, 2010, 04:59:15 pm
Thanks Vince, you da' man!
*confirmed, went in like a charm. 81' 1.6l na caddy btw.
June 07, 2010, 06:34:04 pm
June 07, 2010, 06:34:04 pm »
shouldnt matter either way so long as it's the right size. they look square when you remove them sometimes tho
