Author Topic: engine swap, how hard???  (Read 3639 times)
June 06, 2010, 10:13:39 pm
gribur
  • 84
« on: June 06, 2010, 10:13:39 pm »
i have a wrecked golf with a good AAZ. I was just wondering what is involved if i were to swap it into a gasoline powered golf? I have found one with a great body and if its not too hard to do it would save me a lot of money.
cheers
Reply #1June 07, 2010, 03:02:35 am
Patrick
  • 1034
Re: engine swap, how hard???
« Reply #1 on: June 07, 2010, 03:02:35 am »
Glad you found a good chassis. Should be able to drop it in in a weekend with the right tools. Might take a little longer if you decide to swap the wiring harness too, rather than using the gas harness and addidng a glow plug circuit.
Reply #2June 07, 2010, 07:07:08 am
GEE-BEE
  • 1604
« Reply #2 on: June 07, 2010, 07:07:08 am »
Get a Bosch universal kit ( glowplug) easy install
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3June 08, 2010, 04:27:48 am
rattler
  • 8
« Reply #3 on: June 08, 2010, 04:27:48 am »
GB
Looking at similar swap... Old 1.6 TD engine in a 92 that I have owned for years into a 99 Jetta GT in good shape. Can you provide any additional info on the Bosch universal glowplug kit? Only other challenge is going to be the tach, I really don't want to get rid of those nice silver backed gauges! Oh, and figuring out if the 2.0L serp setup with A/C will bolt on to the 1.6...
JR
Reply #4June 08, 2010, 08:57:17 am
rodpaslow
  • 670
« Reply #4 on: June 08, 2010, 08:57:17 am »
The serp setup will bolt to a 1.6 if you get the deisel serp bracket.  without that it hits the injector pump.  I have a 96 I've put a 1.6 into and I deleted the AC, but stayed with a serp setup.  The only other change is finding a diesel crank pulley or machining a gas one shorter (I had an aluminum one that i machined to fit wider crank sprocket).
Reply #5June 08, 2010, 12:20:29 pm
rattler
  • 8
« Reply #5 on: June 08, 2010, 12:20:29 pm »
Thanks. Great info on the pulley mods! Have to start looking for parts soon... I hate to take out a perfectly good working A/C setup as I don't have a sunroof.
Reply #6June 08, 2010, 03:09:15 pm
GEE-BEE
  • 1604
« Reply #6 on: June 08, 2010, 03:09:15 pm »
GLOWPLUG KIT, run a wire to your ignition, these will turn off auto or when the engine is warm
Ebay item :360225273411
These are the fast type, you can add a led light if you wish...
I just count to 7 and starts like a top....
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #7June 08, 2010, 03:34:10 pm
« Reply #7 on: June 08, 2010, 03:34:10 pm »
I think that's an "add fast glow plugs to a car that already has glow plugs" kit, as opposed to an "add glow plugs to a car that's never had glow plugs before" kit... which I'm wondering is what the OP is actually after?
If it's the latter I don't think I've ever seen a third party relay kit... most people either swap over the diesel harness, fuse block with relay socket etc, or simply add a starter solenoid under the hood and a pushbutton on the dash.  Some thoughts on this approach here:  http://vincewaldon.com/index.php?option=com_content&task=view&id=30&Itemid=28
Reply #8June 09, 2010, 04:21:01 pm
GEE-BEE
  • 1604
« Reply #8 on: June 09, 2010, 04:21:01 pm »
I went from a gasser to a 1.9 aaz, so it's what I used
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #9June 09, 2010, 08:40:48 pm
scottcoreyv
  • 5
« Reply #9 on: June 09, 2010, 08:40:48 pm »
I did the same swap in a weekend, including swaping the harness.
Everything just plugs into the back of the fuse block, the only thing i had to wire was the fuel sender because i swaped tanks.
Reply #10June 10, 2010, 09:56:52 am
rattler
  • 8
« Reply #10 on: June 10, 2010, 09:56:52 am »
How different is the gasser trans gearing? I have a strong engine with a worn out trans (almost 700,000kms). If I am using the gas trans, should I drop in a diesel 5th gear?
Reply #11June 10, 2010, 01:24:28 pm
« Reply #11 on: June 10, 2010, 01:24:28 pm »
Depends on what trans you have ;) Some of the ratios were the same between the two.
On the highway, was the engine screaming? or was it cruising low down in the rpm?
Reply #12June 11, 2010, 06:25:20 am
rattler
  • 8
« Reply #12 on: June 11, 2010, 06:25:20 am »
I'll have to check the trans code... Not sure yet - still in the planning/research (asking questions) stage. Gotta get my wife's old car - 99.5 gas/auto - fixed and sold before I can start another project or I might end up divorced. This will be my first engine swap so I want know have a good idea of what I will be into before I tackle it.
Reply #13June 12, 2010, 09:13:48 am
BAM
« Reply #13 on: June 12, 2010, 09:13:48 am »
This swap is really easy if both are MK3 bodies.  There is minor differences in the wiring harnesses.  93-94 is the same, 95 by itself, 96-98 is the same.  I just did it May 24 weekend.  97 Jetta GL donated engine and harness to a 94 Golf CL 2dr.  I also swapped fuel tank and lines total project about 15 hours.  I had built a transmission during the week before so I did not use the 1.8 gas transmission.  Good luck with the swap.
