Author Topic: 1.6 valve springs in aaz head?  (Read 2072 times)
June 02, 2010, 08:40:05 pm
bugnut
  • 89
« on: June 02, 2010, 08:40:05 pm »
I am working on a 1.9/1.6 engine right now. I have brand new valve springs that I have for my 1.6 head that I am no longer using since I went the 1.9 route.  Question is will the springs from the 1.6 work in the new head.  I see there is a .090" difference between the two springs with the 1.6 springs being longer.  I figure the difference is because the 1.9 is hyd lifter and the 1.6 is solid. With that thinking the vavle stems are shorter in the the 1.9.
All I can figure is there will be more tension on the valve with the longer springs as long as I don't coil bind the longer spring.  Has anyone else tried this?
1980 Rabbit  1.9/1.6 franko engine.  compound built in the works
Reply #1June 03, 2010, 12:37:25 pm
Re: 1.6 valve springs in aaz head?
« Reply #1 on: June 03, 2010, 12:37:25 pm »
im willing to bet you would get some coil bind with the long springs on the short valves.. vw made different springs for different valve train for a reason.
