Author Topic: New diesel owner, swapping a 1.5 into my rabbit GTI.  (Read 4348 times)
June 01, 2010, 03:17:39 pm
vdubspeed
  • 191
« on: June 01, 2010, 03:17:39 pm »
So here's a little backstory:
http://forums.vwvortex.com/showthread.php?4903902-8V-16V-16vT-20V-16v-8V.-My-rabbit-GTI-has-come-full-circle...with-a-twist.
video of the donor:
Diesel Rabbit runs after sitting 18 years.
Now then...I had to add an electric pump to get it to rev up all the way. After doing some reading and discussing with another diesel fan on the vortex I have learned that my vane pump took a shiz and that's why I need the electric pump to keep it primed and revving all the way.
Well the motor is out now getting ready to go into the 84. I was setting everything to TDC and noticed the pump was pissin out of the front seal. Lovely.
So having a bad vane pump and it needing resealed I've decided to get it rebuilt. Who would you recommend? I found one website that seems real legit called www.dieselvw.com
I'm not trying to break the bank here as the whole point of this swap is to save money.
More to follow..
Jason
Reply #1June 01, 2010, 04:10:56 pm
ilikevwdiesel
  • 1202
Re: New diesel owner, swapping a 1.5 into my rabbit GTI.
« Reply #1 on: June 01, 2010, 04:10:56 pm »
you know what I'd do with that pig? just for s&g's, take the fuel line off the pump and stick it right in a bottle of fuel and see if it runs on it's own...if it does just get a pump drive shaft seal from a bosch dealer and stick it in there. i wouldn't be surprised if something was blocked up in the fuel tank/lines making it starve for fuel. of course check the drive shaft for play, there should be NO noticeable play in it. if there is any movement then the bushing is worn and the pump needs an overhaul.
« Last Edit: June 01, 2010, 04:14:28 pm by ilikevwdiesel »
My Bio
Reply #2June 01, 2010, 04:17:18 pm
vdubspeed
  • 191
« Reply #2 on: June 01, 2010, 04:17:18 pm »
I did that. In fact it was the first thing I did. We stuck the line right into a gallon of fuel. No suction.
Had to use gravity to get it to run. The electric pump finally got it revving but then today I noticed the seal leaking so I've decided to just get it rebuilt.
Hence...I need to know a good rebuilder.
Giles wants $650 for a stock rebuild while Roth Engineering wants $220. Both said they will fix the vane pump problem.
WTF would make the price for a rebuild between the two SO great.
Reply #3June 01, 2010, 04:26:41 pm
maxfax
  • 2126
« Reply #3 on: June 01, 2010, 04:26:41 pm »
DO a few searches for Prothe both here and on Vortex, and you will find out why Roth pump "rebuilds" are so much cheaper..   Generally if you get the pump back, and the car will even run at all you are doing good... I'd like to say his product  and service have improved, I thought that once before, but was proven wrong..  Most of the parts he uses are of unknown origin, some work for a while, but generally are still of a lower quality and won;t least near lie the Bosch parts..
Giles is the ideal person to rebuild your pump, not only is his work top notch, but he also sponsors this forum..  However knowing how cost can be a big factor you may want to check your local area for reputable pump rebuilders..
I think I would still maybe try slapping a seal in the front of the pump and see what happens..  It is possible that the seal is bad enough that it's sucking air instead of fuel..  Check the shaft for play before you go too far though...
It is also possible if the engine sat a while that the vanes are simply stuck in the pump..  Some have filled the pump with ATF and left it soak for several days to free them up...
« Last Edit: June 01, 2010, 04:28:45 pm by maxfax »
Reply #4June 01, 2010, 04:31:20 pm
ilikevwdiesel
  • 1202
« Reply #4 on: June 01, 2010, 04:31:20 pm »
I was going to say the same thing...use a marine primer bulb to force marvel mystery oil thru the pump and leave it full of it for a few days... see if it SUCKS then. while you're waiting get a pump shaft seal from a local bosch dealer and install it. you know how to r+r the pump sprocket?
My Bio
Reply #5June 01, 2010, 04:39:48 pm
vdubspeed
  • 191
« Reply #5 on: June 01, 2010, 04:39:48 pm »
shaft is tight. ZERO play.
You know...I'll gladly try slapping on a front seal if I can find a DIY and a quality seal.
I'll ahead and start letting it soak tonight.
For the cost of slapping on a seal and enjoying it for now...it might be worth it.
Any tips on quality front seals and a DIY for that?
Reply #6June 01, 2010, 04:44:41 pm
ilikevwdiesel
  • 1202
« Reply #6 on: June 01, 2010, 04:44:41 pm »
do a web search for authorized bosch dealers with your zip code and see what comes up. they'll need the numbers off the front of the pump housing, like a 0 494 ? number. not the 068 number that's the VW number.
My Bio
Reply #7June 01, 2010, 04:47:06 pm
vdubspeed
  • 191
« Reply #7 on: June 01, 2010, 04:47:06 pm »
will do. Is there a DIY out there for it?
Reply #8June 01, 2010, 04:49:03 pm
ilikevwdiesel
  • 1202
« Reply #8 on: June 01, 2010, 04:49:03 pm »
not sure what you mean by DIY...
My Bio
Reply #9June 01, 2010, 04:55:28 pm
vdubspeed
  • 191
« Reply #9 on: June 01, 2010, 04:55:28 pm »
is there a write up for a do-it-yourselfer?
I found a DIY for a complete pump rebuild but not just a front seal. I guess I can just tear it out and install the new one.
Still trying to locate a bosch dealer. Prothe sells a seal for $4.50 though
Reply #10June 01, 2010, 05:04:14 pm
ilikevwdiesel
  • 1202
« Reply #10 on: June 01, 2010, 05:04:14 pm »
all you have to do is remove the pump sprocket and the seal is exposed. you have to carefully work it out unless you have the groovy bosch seal remover thingamajiggee.
My Bio
Reply #11June 01, 2010, 05:23:16 pm
vdubspeed
  • 191
« Reply #11 on: June 01, 2010, 05:23:16 pm »
wow...something easy on this for once? Thought I would be forced to by a special tool from NASA or something. ;D
Will try the reseal fo sho.
Still trying to locate a Bosch dealer. Anyone have a lead? I live in a SMALL town so no go here.
Reply #12June 01, 2010, 05:24:47 pm
ilikevwdiesel
  • 1202
« Reply #12 on: June 01, 2010, 05:24:47 pm »
dude the bosch corporate death machine headquarters is in Atlanta...right next to Dan Halen Sheetrock International
« Last Edit: June 01, 2010, 05:39:47 pm by ilikevwdiesel »
My Bio
Reply #13June 01, 2010, 06:49:55 pm
« Reply #13 on: June 01, 2010, 06:49:55 pm »
I am surprised that no one wanted to cabbage up the parts or the entire 80 rabbit....you looking to get rid of it??? LOL Just kidding, the wife would cut me, long, deep, and continuously.
Reply #14June 02, 2010, 09:14:45 am
« Reply #14 on: June 02, 2010, 09:14:45 am »
Welcome aboard, its a little nicer over here huh? the guys over here are the most knowledgeable around when it comes to VW diesels. i was also going to tell you about the front seal probably being your culprit too, but then you said you were gonna rebuild it, so i didnt even worry about telling you about that seal. its very easy to replace, and is probably all thats wrong with your pump.
