Author Topic: ideal IDI setup  (Read 4164 times)
May 30, 2010, 05:07:10 am
davechallis
  • 11
ideal IDI setup
« on: May 30, 2010, 05:07:10 am »
hi guys, pretty new to the site but been reading posts on here for a long time. been dabbling with sb engines for a while no and i fancy building an engine. ive heard off some people that an 1900 aaz block and head with sb pump and injectors ect? im just wondering what your opinions are on engine/pump/injector/turbo mixing and what would you say is a good powerful and strong setup. s
sorry if this is a frequently asked question, i have looked but cant find what im looking for.
cheers
dave
Reply #1May 30, 2010, 11:24:46 am
Re: ideal IDI setup
« Reply #1 on: May 30, 2010, 11:24:46 am »
un touched, 1.6 engines are tougher. modified, the AAZ is tougher. but the problem with the AAZ lies in the crank nose.
Reply #2May 30, 2010, 11:37:44 am
Thezorn
  • 381
Re: ideal IDI setup
« Reply #2 on: May 30, 2010, 11:37:44 am »
Yes the problem with AAZ's does lie in the crank nose..
Compounded 93 AAZ
Reply #3May 30, 2010, 01:41:32 pm
davechallis
  • 11
Re: ideal IDI setup
« Reply #3 on: May 30, 2010, 01:41:32 pm »
ok cheers guys, the first vw that got me into the diesels was a mk2 golf i regret selling, the work had already been done and i just had to enjoy it. to me it was a good set up but i am inexpirienced in the diesel world. this was the spec
1600 TD SB
gt15 tdi turbo
8v gti inlet manifold
fmic
1900TD aaz fuel pump turned upto to 1.5 bar boost!!!!!
bit of samco and bit of stainless
id like a similar setup again, maybe with a bit more power if poss, ive looked for a gt15 turbo but cant find another one.
the car
the new diesel motor  i will be building will be going in my early mk2.currently a 1272 on carbs.ive built this one myself
any advice on what i had or help appreciated guys,id just like to know what turbo and what pump ect. thanks for the knowledge and inspiration in advance
Reply #4May 30, 2010, 02:52:06 pm
rallydiesel
  • 1880
Re: ideal IDI setup
« Reply #4 on: May 30, 2010, 02:52:06 pm »
A 1.6TD pump is a great place to start. They can put out A LOT of fuel. If you want more, you can swap in a 1.9 (AAZ) pump camplate. Same with the injectors. If you want to start delving into bigger turbos, mid-sized vnts (from the pd150, various 6 cyl. diesel Mercedes, Saabs, etc.) are great. There's some excellent mechanical vane controller ideas you can build yourself. If you are going to go high output than I would highly recommend porting out the head (1.6 or 1.9 is even better). Also, some of the new ARP studs will help keep the headgasket from blowing.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #5May 31, 2010, 12:24:02 am
davechallis
  • 11
Re: ideal IDI setup
« Reply #5 on: May 31, 2010, 12:24:02 am »
ok thanks for that, to be honest my pump is buggered, due to being standing, ive been told that its internal corrosion so its full of atf at the moment. if my pump is kaput, i may opt for the 1900 option, depending onm what is avalible. id love to go big on my build but dont feel i am expirienced enough in diesel engines yet. my plan is to keep reading threads on here and build a motor similar to the one i used to have so i can learn more hands on diesel expirience
thanks
Reply #6June 04, 2010, 09:35:59 am
Mark(The Miser)UK
  • 1557
Re: ideal IDI setup
« Reply #6 on: June 04, 2010, 09:35:59 am »
At a guess; what your Nice AAZ pump setup lacked, was a 1.6TD LDA cone, because the standard one has minimal extra fuelling. You would have seen more oomph ;D
Intercooler from a GTD/ Passat mk3 would be the way to go too....
Mark-The-Miser-UK
Reply #7June 04, 2010, 09:56:14 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
Re: ideal IDI setup
« Reply #7 on: June 04, 2010, 09:56:14 am »
Quote from: Mark
Intercooler from a GTD[/color]
Interwarmer in standard location
Or mine seems to be as I've had 2 and they were warm on both sides
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
