Loud ticking in 5th gear VIDEO
Topic: Loud ticking in 5th gear VIDEO (Read 3034 times)
May 27, 2010, 09:25:56 pm
dankcorey22
Cummins!
May 27, 2010, 09:25:56 pm »
Hello guys i have a video of this ticking or rather banging somewhere in the transmission. ive looked under the hood and nothing is hitting even when i put it in 5th gear. im thinking its the throw out bearing maybe but im not really sure but heres the videos...
I know its not that much help but it gives you an idea. its gets loud when i press the throttle, then when i let off its gets quite only in 5th gear... its weird
Its a very faint sound on the video but in the car its loud
Banging in 5th gear.3g2
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
May 27, 2010, 10:32:43 pm
Re: Loud ticking in 5th gear VIDEO
May 27, 2010, 10:32:43 pm »
Only in fifth gear huh? thats weird. If it were the throw out bearing as you suggest, I think the sound would be apparent in all the gears, no?
Hmm, maybe it is an unbalanced tire? or maybe a failing CV?
May 28, 2010, 04:36:16 am
May 28, 2010, 04:36:16 am »
I haven't heard what the self machining syndrome sounds like, but maybe it is that. Also, if you run these low on oil the fifth gear is the one that gets hot and then wants to break.
That being said all I can hear is what sounds like a wheel bearing up front. They usually get better or worse on turns and load though.
Round 2
May 28, 2010, 07:47:17 am
dankcorey22
Cummins!
May 28, 2010, 07:47:17 am »
Yes the throw out bearing should be in all gears. it maybe a failed CV. when i wiggle the CV axels its kinda like its wore out.
@theman53 what is the machining syndrome sound? and it get worse with load
May 28, 2010, 02:20:46 pm
May 28, 2010, 02:20:46 pm »
from what I have heard once you hear it it is too late. I don't know I am sure you could search, but the SMS basically puts a hole in the side of your case and all the oil runs out.
Round 2
May 28, 2010, 02:22:07 pm
May 28, 2010, 02:22:07 pm »
www.brokevw.com
May 28, 2010, 04:38:59 pm
dankcorey22
Cummins!
May 28, 2010, 04:38:59 pm »
Well my engines using oil like crazy so i might just rebuild it. and in the process get a good used transmission and CV axles
May 28, 2010, 05:41:25 pm
May 28, 2010, 05:41:25 pm »
That is how my build started
Good luck.
Round 2
May 28, 2010, 07:10:14 pm
dankcorey22
Cummins!
May 28, 2010, 07:10:14 pm »
Thanks man
any advice on the build? im fully committed now!
May 28, 2010, 07:29:50 pm
May 28, 2010, 07:29:50 pm »
You're transmission oil has gotten too low. 5 th is now shot, maybe even the shaft, that's why it's noisy. Gears are sloppy .
May 29, 2010, 05:18:32 pm
dankcorey22
Cummins!
May 29, 2010, 05:18:32 pm »
theres nothin i can do to help it? put more gear oil in it?
Reply #11
May 29, 2010, 05:24:20 pm
Reply #11 on:
May 29, 2010, 05:24:20 pm »
Check out Broke's site, as I suggested, to see some pictures of what the damage caused by running low on oil looks like. It's the result of overheating, which is a 1-way ticket.
