Author Topic: More Noise - this could mess up my weekend  (Read 3425 times)
May 25, 2010, 04:33:58 pm
rs899
  • 647
« on: May 25, 2010, 04:33:58 pm »
This recently acquired 91 Jetta is giving me fits getting it sorted.  I found a bad wheel bearing, struts are shot and I am getting this vibration/noise right in front of me  at about 45 mostly when I decelerate.  I thought it might be inner CV joint- not so sure now.  Also getting a small rattle coming from the clutch area at startup that goes away when you push the clutch in.  I was thinking of pulling her apart this weekend to see if perhaps one of the clutch springs was about to exit ( I have had that happen)
I have the car up on jackstands with both the axles off.  I start the car and put in all the gears.  No real issues at normal engine speeds but at idle in gear there is a very pronounced rattle coming from the transmission/bellhousing area in 3rd 4th and 5th.  Does this sound "normal"?  Would that point to further issues in the flywheel/pressure plate area?
Advice cognoscenti gearheads?
Rick
sorry for so many questions lately....
Reply #1May 30, 2010, 02:25:21 pm
smutts
  • 720
    ClackClackClackClackClack
Re: More Noise - this could mess up my weekend
« Reply #1 on: May 30, 2010, 02:25:21 pm »
Clutch rattle sounds likely.
