Author Topic: Headgasket problem.  (Read 1987 times)
May 25, 2010, 04:03:23 pm
dash cunning
  • 47
Headgasket problem.
« on: May 25, 2010, 04:03:23 pm »
I ordered a new gasket from autohausaz and it seems to be missing some cooling holes in it. am i correct in assuming this from the pics below? i've read that it's kinda normal for some gaskets to come without the holes but i can't find any info on if i should drill the holes out. can i just drill some holes there or are they not there for a reason, the head has the same holes in it. thanks guys. The area i'm talkin about is to the left and right of the big water passage.
head
gasket.
« Last Edit: May 25, 2010, 04:10:01 pm by dash cunning »
79' rabbit 1.5 n/a, 89 golf gasser, 91 jetta gasser, 72 westy.
Reply #1May 26, 2010, 06:50:24 am
dash cunning
  • 47
Re: Headgasket problem.
« Reply #1 on: May 26, 2010, 06:50:24 am »
b
Reply #2May 26, 2010, 04:27:01 pm
dash cunning
  • 47
« Reply #2 on: May 26, 2010, 04:27:01 pm »
anyone?
Reply #3May 26, 2010, 04:43:52 pm
« Reply #3 on: May 26, 2010, 04:43:52 pm »
I could be out to lunch but I thought that was done to allow even coolant flow
Reply #4May 31, 2010, 05:46:00 pm
dash cunning
  • 47
« Reply #4 on: May 31, 2010, 05:46:00 pm »
its out of an 81. 11mm head. i just sold my inari rabbit and got a truck that has 12mm headbolts with low compression in one cylinder, so i'm hoping it's just a head gasket and i can throw my turbo setup on it and save this motor for when the other one goes. i'm gonna be towing a light boat with it so hopefully all will be well.
